Is this transformer bad? (Measurements inside)
  • orientalsniper
    • Apr 2013
    • 461
    Hello all, I have never tested a transformer before, this is the reading (out of circuit) I got:
    1-(2-6) = open
    7-(2-6) = open
    1-7 = 0 ohm
    1-8 = 4 Mohms
    1-9 = 7 Mohms
    7-8 = 0.5 Mohms
    7-9 = 3 Mohms
    I attached picture of transformer with the pins sequence. It's an IT-003 inverter transformer.
    If it's bad, do I have to find an exact replacement? I have lots of dead PSU's laying around, the transformers are not the same, how do I solder them to test on the inverter board?
    Problem with monitor is going dark after 2 seconds (the backlight, power LED is still powered on).
    Re: Is this transformer bad? (Measurements inside)
    Looking at your picture, Pin 1 & 7 are for the Primary winding, it will have very Low OHM.
    Pin 8 & 9 are for the high Voltage winding, typical value can be from 500~1K Ohms range.
    Compare the readings of this transformer with the other one that is the same as this one.
    • orientalsniper
      • Apr 2013
      • 461
      Hey, thanks for your reply, I don't have another similar inverter transformer, what I meant was that I had tons of transformer for power supplies.
      Can I use those? They don't even have the same amount of pins.
      • munja
        • Apr 2015
        • 5
        • Serbia
        1 & 7 are primary winding 0,2-0,5 OHMs,8 & 9 are secondary winding and value can be 500-1,5 KOHM .....your transformer is bad.....between primary and secondary is infinite resistance
          Nope, you have to get the same one.
          What kind of monitor is this that uses only one small inverter transformer?
          Inverter transformer output voltage is around 1500V start and then drops down to about 800~1000V once the lamp is on.
          • orientalsniper
            • Apr 2013
            • 461
            It's an LG W1943. Forgive me if I'm wrong, so if 8 and 9 are secondaries, they should be shorting right?
            Because, measuring pin 8 against pin 9, I'm getting 0.9 Kohms.
              "Because, measuring pin 8 against pin 9, I'm getting 0.9 Kohms." That is about right.
              It may have lamp problem, power supply problem, inverter circuit problem, etc.
              • orientalsniper
                • Apr 2013
                • 461
                Thank you both! I will order a new transformer.
                  I doubt that it is bad transformer. The mega ohms reading may be due to your hands are on the probes and it shows your body resistance.
                    • 31284
                    try it wih a cfl instead of the original lamp(s)
                    • orientalsniper
                      • Apr 2013
                      • 461
                      My bad! I misread your reply, you were right, that was my body resistance, primary against secondary reads infinity.
                      I don't think it's the lamp, because I'm having same problem with my inverter tester (turns off after 2 seconds).
                      Here's photo of tester: http://i.imgur.com/iyWbEBR.jpg
                      Thank you. At least I know transformer is good, so I can keep testing the other components.
                        • 31284
                        the 8pin chip on the right is the fet that drives the transformer,
                        the big cap on it's side try's to stop the circuit effecting anyting else.
                        how does that tester work?
                        • orientalsniper
                          • Apr 2013
                          • 461
                          The little lamp above the words "Inverter Tester" is a small lamp. I plug it into inverter boards and it should light up.
                          About the 8-pin mosfet, pin 2 has 3V for only 2 seconds. and the big capacitor has 12V always. I'm checking the schematics for more information.
                            • 31284
                            the controller chip is shutting down drive to the fet.
                            • orientalsniper
                              • Apr 2013
                              • 461
                              By controller, I assume you mean the inverter driver:
                              Should I replace the IC or bridging 3V to pin2 of FET should be enough?
                                Check the resistance between the Source and the Drain pin of the power MOSFETs that drives the inverter transformer to see if it shows any resistance.
                                • orientalsniper
                                  • Apr 2013
                                  • 461
                                  I think mosfet is fine, N channel is 10 Mohms and P channel is 3 Mohms. (Resistance between Source and Drain according to: )
                                  • orientalsniper
                                    • Apr 2013
                                    • 461
                                    My bad! I was testing in circuit, out of circuit, N channel has infinite resistance, so I guess the mosfet is the one with issues, can I jump any pin without replacing this mosfet?
                                      • 31284
                                      no jumping of anything.
                                      • Flaku_34
                                        Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                        by Flaku_34
                                        Introduction:
                                        Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                        04-18-2024, 12:47 PM
                                      • learnmore
                                        Help choosing replacement transformer for Levoit 600S SMPS
                                        by learnmore
                                        Hello Community,
                                        I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                        Peace
                                        LM...
                                        11-04-2025, 09:35 AM
                                      • eccerr0r
                                        inverter H tree driver imbalance in an AC inverter
                                        by eccerr0r
                                        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                        Today, 12:34 PM
                                      • mikey5791
                                        Is it possible for transformer substitution?
                                        by mikey5791
                                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                        My questions are
                                        1. How do i test to see if the transformer is in good working condition?
                                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                        Hope you guys understand what i was asking. My intention is...
                                        11-03-2022, 02:11 AM
                                      • x_orange90_x
                                        by x_orange90_x
                                        01-29-2025, 09:24 PM
