Where can I buy transformers in UK
    • 31117
    Re: Where can I buy transformers in UK
    Originally posted by budm
    I need better focused pictures of the bottom side of the board.
    i cant even see any in the entire thread!
    • Ice203
      • May 2015
      • 99
      • Uk
        check the MOSFET.
        • Ice203
          • May 2015
          • 99
          • Uk
          Hi. Can they be tested in circuit.
          • vinceroger69
            • Mar 2012
            • 6714
            yes test in circuit then if odd readings remove and re test.
            • caseyjay_48
              Sony KDL-46BX450 Inverter Troubleshoot Logic
              by caseyjay_48
              I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
              I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
              09-23-2022, 08:08 PM
            • amelbye
              is it ok to replace a dual output transformer with two single output transformers?
              by amelbye
              Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
              Now that's a challenge - luckily...
              08-21-2020, 08:51 AM
            • ohren
              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
              by ohren
              Hello!
              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
              Measured voltages with no load:
              After rectifier diodes
              12V: 6.17 V
              5V: 5.67 V
              Secondary transformer pins AC measurement (really don't know if this says anything)
              12V: 2-2.5 V
              5V: 1.04 V
              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
              03-18-2023, 10:33 AM
            • mikey5791
              Is it possible for transformer substitution?
              by mikey5791
              Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
              Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
              My questions are
              1. How do i test to see if the transformer is in good working condition?
              2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
              Hope you guys understand what i was asking. My intention is...
              11-03-2022, 02:11 AM
            • x_orange90_x
              by x_orange90_x
              01-29-2025, 09:24 PM
