I have a Vizio VT420M that seems to turn on but I can't see picture.
I suspect Power supply part number: PWTV9QH1GAC9
The logo at the very bottom goes from dim orange to bright orange when I press the power button, and the backlight never comes on. The flash light test yields no picture.
Using a DMM I got perfect voltages for all pins going to the main. So far it sounds like a bad main, but I wanted to test the PS before ruling it out. Checked all caps, all fuses, and diodes. After my check I found something a little odd on 2 diodes sitting next to eachother.
D9404 was showing voltages passing both ways at 0.210V
D9403 had 0.276V passing the way its supposed to and .590v passing when it should show OL
I measured them out of circuit, and both measured .301v one way, and OL the other way. So the diodes are good. I check the board again, and it looks like the measurement if coming from something else on the board
I buy a PS from Payless components, they have been good to me in the past, and before installing it, measure the diodes on it due to curiosity. I got the exact same result as on my board, I plug the thing in anyways, and I get the same symptoms.
Is this just the way this PS is designed, and my issue is indeed coming from the main board, or is this a common failure on these Power supplies and I just got a bad power board sent to me?
Thanks to everyone that can help me figure out if my main is bad or if my power supply is bad
