Ok I have the LCD TV L32WD22 here and just as the title says I have no 15v no 24v and no backlight.
Obvious thing no 24v = no backlight
Anyhow I am curious.
I checked all caps with an ESR meter in circuit and all tested fine accept for one replaced that.
The ESR I have does not work for the 450v value so I replaced the cold side cap at 450v 100uf still a no go.
All voltage regs on main board test good the ones labeled for voltage tested at that voltage or close to it.
All the others tested within spec according to the datasheet. Which if I recall was like 5v and 2.8v.
Quite the oddity I've checked a few SMD diodes as well as radials and zenners just in case they all seem to throw a reading one way and none the other accept for 3 of the SMD which was somewhat typical for this SMD diode if I recall correct... .019 both ways on main board.
Finally I am at a loss as to where the 15v is not getting power and the 24v is not getting power the on off is 2.86v and the Dim is the same.
I am a bit curious on how to go further.
Note I never checked the hot side filter cap 450v 100uf it is the only large cap out of two that is on the board that did not get tested nor replaced.
This TV has been a nightmare thus far wasted an entire weekend on it with zero satisfaction usually I can figure this stuff out but I am stumped.
