Phillips 47PFL3603D/F7 No Power
  • Granger
    • Jan 2015
    • 3
    Re: Phillips 47PFL3603D/F7 No Power
    I appreciate all the info shared in this post. I was able to revive my brother's 47-inch Philips that had the flamed out C700. Burned a hole straight through the board. When I saw it I didn't think there was much hope. I couldn't even read the top of the cap it was burned so bad. Turns out the transformer was ok, after I cleaned all the soot and carbon from it. I used a (brown) Xicon 220nF/630V film cap, and had to wire the cap directly to the Xformer terminal, as the pad was completely gone.
    The TV is working fine so far on day 2.
    • electomech-fixer
      First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
      by electomech-fixer
      I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
      I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
      09-15-2025, 01:42 AM
    • Samuel Vincze
      Hp 250 g6 burnt IC on the motherboard - is labeled 3h=5g
      by Samuel Vincze
      Hello, my HP doesn't start, and I found a burnt IC on the motherboard. I can't read the full description due to the damage. The component is labeled 3h=5g. Could someone please advise me where I could buy the component or its suitable replacement? Thank you. It's marked as PUG8 on the motherboard.
      02-16-2024, 05:53 AM
    • nmbb
      Can not find Model/Value of Thermistor.
      by nmbb
      Machine: Autoclave.
      Brand/Model: SANYO MLS-3780
      Manual: (Sorry search option not working on this PDF)
      Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
      06-02-2022, 05:55 PM
    • dicky96
      Zotac GTX 260 burnt component - can anyone identify?
      by dicky96
      Hi guys
      This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
      This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
      Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
      I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
      The good phase...
      12-01-2021, 01:02 PM
    • swimllamaswim
      Precision 5550 LA-J191P No Power, Burnt ISL9538
      by swimllamaswim
      I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
      Here are the voltages measured at that chip:
      To note, DCIN at Pin 17 is low,...
      09-21-2025, 12:26 PM
