is there anyway to fix a main board?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I have this lg 55LH90-UB AUSVLHR. wont power up. has the standby voltage but no pwr_on voltage so my theory is the main board is bad. its main board
    EBU60695001. I tried to find one but there is none available and shop jimmy had it priced at 175$ but didn't have any. but I still would like to know is there anyway to fix these? I have never done such a thing, I cant locate a surface mount fuse anywhere
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: is there anyway to fix a main board?
    Anybody please
      Did you try pushing that switch (TV plugged in) by the barcode sticker to see what happen?
      • mattstolte
        • Dec 2013
        • 612
        • usa
        Yes, there are 2 switches. Tried them both no luck
        • newtothis
          • Mar 2013
          • 1556
          • england
          Without a schematic its going to be very difficult
          • selldoor
            Slow Learner
            • 7870
            If you can find the PSON pin work back from there and see if you can find anything faulty.
            Test voltage regulators and test for voltage on caps are easy tests.
            Zero rated resistors with a 0 on are often used as jumpers but sometimes have a fuse function.
            • mattstolte
              • Dec 2013
              • 612
              • usa
              the bottom pin is the pwr-on but I wouldn't even know where to begin or how to trace a line? I don't even know how to test these things so if anybody can tell me what to put my meter on when checking them?
                • 31046
                check the power at the main cips,
                check the crystals are oscillating.
                if that's good, probe the eeprom/flash to see if it's being read at powerup.
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                  by JDC
                  ONN 100012588
                  Issue: No Power, Then Rebooting After Main Board Change
                  Short answer: replace main board and power board
                  Technical answer: replace main board and Q306 & Q307 on power board.
                  Long answer:
                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                  07-15-2022, 07:39 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
