RCA 46LA45RQ 2 seconds then lights out, intermittent
  • rockola1454
    • Oct 2014
    • 42
    I have an RCA 46LA45RQ which I am attempting to bring back to life. Some of the time it comes on with no issue and works fine for hours. The other half of the time, the backlight goes out after 2 seconds (a flashlight can show the image). When it comes on in this "mood," turning it off/on repeatedly has no effect.
    I first tried a factory reset, to no avail.
    Next, I suspected the Megmeet psu. I tried running a heatgun over the psu for a bit to gently warm things up, but the lights still go out after 2 seconds. Not satisfied, I tested all electrolytics on the psu, finding none bad or significantly out of range.
    I then made the assumption the Samsung SSI460_12A01 inverter was faulty, and obtained a new one. Unfortunately, still no difference. On both the old and new inverter board, I see 24 volts steady regardless of whether the light stays on or not.
    I don't know if this means anything, but through holes in the back of the panel's metal frame I can see the light start out and in a fraction of a second get 20% brighter when (and only when) the lights decide to stay on. Watching from the back I can usually predict the lights will go out if the lights don't start then very quickly get a little brighter.
    Any advice appreciated!
    -Chris
  • rockola1454
    • Oct 2014
    • 42
    Re: RCA 46LA45RQ 2 seconds then lights out, intermittent
    I'm wondering if I should get a replacement power supply, or if I should look in the direction of the cfl bulbs being bad. Any thoughts?
      https://www.badcaps.net/forum/showthread.php?t=39740
      • rockola1454
        • Oct 2014
        • 42
        Ah, I'm sorry about that, I totally missed adding pictures. Here are some. Since I have a spare of the inverter board, I just laid it on the panel in the first picture for reference.
        If close-ups of anything in particular would be helpful please let me know, I'm happy to take as many as needed.
        And thanks for any help you can provide!
        • newtothis
          • Mar 2013
          • 1556
          • england
          So...
          Swapped Invertor no change, 24v present at invertor regardless of if the backlight is on off? Correct?
          Leaves one thing - Failing CCFL
          • rockola1454
            • Oct 2014
            • 42
            Thanks! That makes sense. I took the panel assembly apart and have the bulbs exposed. They all stay lit at the moment, but one bulb had a "barbers-pole" look to it for several seconds. I'll keep trying it today to confirm if that is the (only) problem bulb.
            If I've done my measurement right, I'll be looking for a 4.0 x 1025mm bulb. Any recommended places to buy them? I noticed www.ccflwarehouse.com...
            Also reading through the threads, seems like I need to wipe down the panel with a dust cloth prior to reassmbly, someone recommended Guardsman.
            • rockola1454
              • Oct 2014
              • 42
              I believe the problem is solved!
              Was powering the set on/off on its back without the LCD panel for a good while trying to determine which bulb is bad, but without any failures. I decided to inspect the connections of each bulb more closely and found 2 ground sockets "unlocked" themselves. The cathodes of the bulbs were pretty black in those sockets; some light sandpaper brought back the shiny color. Locked them back in by pressing down on the sockets with my thumb and haven't had any problems so far. Awaiting an anti-static wipe to put the panel back.
              Thanks again for pointing me in the right direction, guys! Hope this post helps someone else with the same issue. Beers on me!
              -Chris
                Good job!. I can see some of the lamps has blackened ends so they will more likely to fail later, if it has backlights level control, I would set it to about 80% or so that may extend the life of the lamps.
                • Watts
                  • Feb 2017
                  • 4
                  • usa
                  Hi all
                  I have a late model rca 46la45rq with the samgsung LCD assembly and having
                  almost the same problem. I walked out of the room and when I came back the lcd was dark but sound was still working. The flashlight test showed the image was was there so I assumed the inverter was bad. Up until that time the lcd was bright and clear but since then the 2 second on then off is it.
                  The power supply board seems to be working fine with all votages dead on.
                  Resistance test showed very similar accross all 3 tranformers and surrounding circuits. I have a small handheld video game that I use as a A/V source and for the 2 seconds the image is bright and clear.
                  pics
                  https://s28.postimg.org/9byvklr4d/DSC00195.jpg
                  main board
                  https://s24.postimg.org/sxjfhp79h/DSC00185.jpg
                  Power board
                  https://s27.postimg.org/l7afyzer7/DSC00188.jpg
                  Inverter board
                  https://s29.postimg.org/ltno9ea87/DSC00204.jpg
                  First I would like to know if anyone has a service manual for this set or
                  provide me information for trouble shooting the senser circuit. I will open up the backlight cage tomorrow and check the connections as mentioned by the previous poster but don't expect to find anything there.
                  Here is a pic to the one possible problem area that I found. If I measure the
                  voltage on the pin on the inverter board at power up the voltage is 5.0 but
                  as soon as the tubs fire up the voltage drops to 3.24. I don't know if these
                  voltages are normal or not but for now it's the only thing I have found.
                  https://s29.postimg.org/rc0at19on/notes.png
                  Thanks in advance
                  Watts
                  • Watts
                    • Feb 2017
                    • 4
                    • usa
                    Forgot to mention the inverter number is SSI460_12F01 SSI460-12F01 LJ97-03319A
                    • Watts
                      • Feb 2017
                      • 4
                      • usa
                      Another picture showing the other end of the 3-pins shown in the last pic
                      • Watts
                        • Feb 2017
                        • 4
                        • usa
                        my bad, here is the link. https://s29.postimg.org/ela7eg9ef/note_2.png
                        • CapLeaker
                          Leaking Member
                          • 8352
                          measure the secondary HV output winding with your meter set to ohms of each transformer on the inverter board. Compare them to each other. If there is more than a 3% difference in reading, the transformer is bad.
                          Usually there are bad capacitors (specifically those under the heat sink on the PSU) and those caps on the inverter board, bad HV transformer on inverter board and last RCA has bad connections at the lamps and or wiring between CCFLs and inverter board.
                          • liquidzorch
                            Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                            by liquidzorch
                            Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                            10-18-2024, 05:19 PM
                          • twonk9098
                            Lenovo Legion 5 high fan spin turns off after 34 seconds
                            by twonk9098
                            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                            I have tried a few new bios but exactly...
                            07-14-2024, 11:19 AM
                          • fab13
                            PS4 lights up for a few seconds (blue led) and shuts down - non-rotating fan
                            by fab13
                            I have a ps4 Fat CUH-1116A, the worry is that when I got it back it turns on with the blue leds and a few seconds it turns off and you have to turn it back on and it turns off again.
                            It seems to be in security.
                            The fan does not turn even with a new one
                            Motherboard SAB-001
                            Checking made:
                            - New power supply block OK and even with another one always the same problem
                            - PS4 metal sheet is not too screwed
                            - New thermal paste and new fan
                            - Voltage 12 Volts arrived on the fan, no short circuit on the 12 V ...
                            11-26-2022, 09:00 AM
                          • Victor Moreira Silva
                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                            by Victor Moreira Silva
                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                            Well, my decice specs are the following:
                            Model: Acer Nitro 5 AN517-54-55T5
                            CPU: Intel Core i5-11400H
                            GPU: NVIDIA GeForce GTX 1650
                            Motherboard: GH51G LA-L181P Rev:1c
                            The symptom:
                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                            05-26-2025, 10:49 AM
