Re: Samsung PS-42S4H flashing pixelated screen
To remove I just used a hot air wand and plenty of flux, The hardest part is just making sure the grounding solder in the centre of this IC is melted enough so then the pins can become free from the pads at the same time.
To attach I just used my soldering iron with a fine tip and again plenty of flux. u need to make sure all remaining solder from the ground point under the IC is completely gone or the IC will not sit flat. Plenty of flux and Goot wick works good here.
whole removal and replacement mayb took an hour and a bit? not sure exactly as I removed this IC and cleaned up the board before my replacements came
