Samsung LN52A550 Tab bond faulure or bad screen?
  • coreyand
    • Nov 2014
    • 88
    I got this 52" from a guy down the road, the screen was not this bad off until I started messing with the tab bondings. If I hold some of them with only 2 hands and some ample pressure I can nearly get half of the screen back. I have an exact match TCON board for this tv(im not 100% if its good or not) but when I install the TCON into the tv I get the same picture so that leads me to believe that it is most likely the screen.
    My question is, is this screen too far gone with bad tab bonds or could it possibly be repaired by a method like budm here https://www.badcaps.net/forum/showth...udm+52+samsung
    Any feedback would be helpful, attempt the fix if it is the tab bondings or just part the tv out.
    Thanks for your opinion guys.
    Corey.
    Re: Samsung LN52A550 Tab bond faulure or bad screen?
    Try flexing the screen to see if it will make it change what you see on the screen, also try re-seating the cables.
    • mross76
      • Mar 2015
      • 12
      • usa
      i have a similar problem
      • coreyand
        • Nov 2014
        • 88
        Flexing changed a little bit of the lines and what not. Reseating the cables I didnt notice a difference.
        • 102mm
          • Dec 2013
          • 181
          • us
          Tabs for sure.. Ive fixed 2 of those models. they haven't had any other problems for over 18 months now.
          Craigslist Picks & Fixes
          2 ea - Samsung 52"
          Samsung 60"
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            102, did you use Buds method or something else?
            • coreyand
              • Nov 2014
              • 88
              I have tried, I am seeming to be unsuccessful at restoring the panel by messing with the tabs. Is it possible that the panel is just bad?
                Yes, a bad panel is possible. Samsung have a lot of issues in this regard.
                • coreyand
                  • Nov 2014
                  • 88
                  That stinks. The side with the vertical lines I cant get hardly anything to change with that, and the other side I can get to clear up but only about 2/3 of the half of the screen. Thinking it was a tcon I replaced it with the same result. Im calling it on this one guys, a bad panel I suppose.
                  • 102mm
                    • Dec 2013
                    • 181
                    • us
                    No.. Actually i found the fix on accident.. i had the tabs exposed and touched one of the flex cables accidentally and it cleared up for a sec.. i fixed both of the TVs i had the same way, a little piece of material to act as a heatsink for the chip on the ribbon cable going to the panel
                    2 ea - Samsung 52"
                    Samsung 60"
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • Chrissygizmo
                      samsung galaxy ao2s very temperamental after screen replaced
                      by Chrissygizmo
                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                      Ive eventually managed to get it on and working but it's very temperamental...
                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                      05-26-2024, 12:05 AM
                    • Kiberge
                      Samsung LH82QENELGC/EN Help needed - Static line on screen
                      by Kiberge
                      HI guys!
                      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                      04-22-2024, 11:28 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • kotel studios
                      Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                      by kotel studios
                      Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                      In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                      08-06-2025, 02:07 AM
