I Received this TV from a family member that had it for maybe 2-3 years. From what I was told, the TV would periodically go to a black screen, or shut off as they would say. But, from what I have read about the TV automatically doing app and firmware updates, that it sounds like they may have mistaken updates to the set for shut downs.
Either way, the set now has nothing but a black screen when turned on... The logo will alternate between orange and white for maybe 30 secs, (warming up the backlight?) then stay solid orange. After that, hitting the power button again causes the logo to change to solid white. Unfortunately, that's it. No VIZIO logo on screen, the power dial on the side brings up no menu prompts.
I have tried all the inputs, as well as cycling through inputs with the remote. I have also unplugged for a hard reset, as well as unplugging, and holding the power dial in for 30 secs. (Which I read was another way to do the reset?) I don't have any testing equipment, and I'm not sure if I would know what I was doing even with instruction....
NOW, on the other hand. I don't have any issue at all when it comes to installing a new board if needed. From what I have been reading a lot of times it sounded like replacing the power supply board fixed the issue. A couple of posts though had said a new T-con board did the trick.
I have contacted a seller in advance about exchanging one board for another if the first one I tried just by guessing didn't work... I know it's not the smartest way to go, but for what this set can do, I feel like it is worth a couple hundred bucks at most to fix. I know it is not much to go on, but maybe even an educated guess could help.
Thanks in advance though to anyone that tries.
