I have a Sharp LC-C5255U and can't find error codes but found for a similar model like LC-52D64U. The OPC and Power light lights up at the same time and then the Power light will flash by itself another 2 times. Is this a 1-2 code or a 1-3 code? The 64U says it is a 10v failure for 1 opc and 2 power flash. I do not have a 1-3 code data if it is that. Symptoms is it tries to turn on 3 times and gives up with the code. No back and no pic. thanks. If you have codes or service manual..lmk. Tanya had nothing.
Sharp OPC Codes Question - EASY!!
Re: Sharp OPC Codes Question - EASY!!
If you would have posted some pictures You may have had more help. If it IS like a LC-52D64U I would check the inverter transformers, I had one once that had a bad transformer, try checking the resistance of the windings and compairing them, if one is open that would shut the set down. Does one of the inverter boards look like this one? The manual for the LC-52D64U can be found onlineAttached Filesif you find these attachements useful please consider making a small donation to the site
looks like you have a 3-1 code (COMMUNICATION ERROR).
Try unplugging and then hold down vol- and channel+ while plugging back in and see what happens.Comment
Well I know you guys like pictures but I had no idea what picture you would want? First thing I did was that I did get a new set of inverters as I know that's a common failure. Same result and yes they do look like the picture above. Communication error? Would that be with the main? I did order a new main and haven't tried yet as it just came in. I know these sets have bad bulbs also but didn't seem like a 3-1 code would come from bad bulbs. Hopefully the main will work and will post in 12 hours on that. The only other thing I could think of is TCON? The customer said he changed out the power which to me tests fine. I do get the 60 volts to the inverters. The TV cycles 3 times and then shuts off. Not light, video or anything. No response from on/off buttons! Tried to force on via Ch- and vol - but that did nothing. Thanks.Comment
Service manual may be close enough for the error codes:
https://docs.google.com/file/d/0B3xF...YkU/edit?pli=1
Pictures of the whole back side of the TV will help.
Lots of boards used in the same model as your and in LC52SB55U.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks a bunch. I didn't have the 3 blink power code page. Sounds like a main board and will have to see if I can repair it. If not..I do have a back up main to use. Will add to this later. Thanks for posting these pages.Comment
Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
Regards,... -
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by gavenbHi folks!
I have a LC-80LE661U that had some interesting issues.
Initially, it would come on and show the sharp logo and would show normal static before shutting off.
I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it... -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM - Loading...
