Samsung UN32F5500 smart TV no backlight
  • Terryfictv
    • Mar 2011
    • 124
    Re: Samsung UN32F5500 smart TV no backlight
    Yes,indeed we are all in the same bind!I have a UN32F series with all
    strips bad. Part number D2GE-320SC0-R3 Mfr.by LUMENS.We need a source,
    even China will do!
    • thoma
      • Sep 2012
      • 268
      LED Stripes for LED TV
      http://www.shopjimmy.com/tvs/tv-led-light-strip
      http://www.ebay.com/bhp/led-backlight-strip
      • siddhu
        • Jul 2015
        • 17
        • india
        Hi, I have the same tv UN32F5500 with same issue, flash light test passed so back light issue.
        Help me with further trouble shooting.
        Need help to check if the output from led driver is proper.
        If that is fine then need help to check if the led strips are fine.
        • Truncatedhose
          • Oct 2014
          • 343
          How hard is to get to the LED strips in this model? Can you describe the process for me? Thanks!
          • paulstef
            • Dec 2013
            • 724
            Same problem. Would be nice to know the EXACT wiring of the strips. My panel is not open yet though.
            Tested them all with 20 to 25V.
            +-4 does not light up
            +-3 does light up
            +-2 does light up
            +-1 does not light up
            IF1 IF2 does not light up
            They don't seem to be all equal, or why would they give a different name to the last pair?
              All 4 strips are connected in series, the one I work on has one strip with shorted out LED, and another strip has open LED, very common failure.
              https://www.badcaps.net/forum/showthread.php?t=46403
              You will have scrape off the white paint to make contact with each LED legs, the LEDs in each strip are connected in series.
              • paulstef
                • Dec 2013
                • 724
                They must be connected in series on the PSU PCB then , correct? Or why would there be 10 wires going from PSU to LEDs?
                • mrhappypants
                  • Aug 2015
                  • 8
                  • canada
                  #28
                  there are 5 strips not 4.
                  they are all in series, but 4 and 5 are connected in series inside the panel. So when you test +4 -4, you are actually testing 18 LEDs not 9 LEDs like the other ones. You would have to give it 40 volts probably to get them to light up.
                  • paulstef
                    • Dec 2013
                    • 724
                    Thing is I wanted to be sure they are faulty before opening up the panel.
                    +-3 and +-2 both light up at about 20 to 25V, with +-2 being brighter than +-3.
                    You say they are all in series inside the panel (i.e. not on the PCB). Then why are there 2 wires for (supposedly) each of the strings coming from the PCB?
                    • mrhappypants
                      • Aug 2015
                      • 8
                      • canada
                      #30
                      okay. i'll try and clear this up. The power supply puts out the full voltage of 160V on 1+, it goes out to string 1, then comes back on 1-, then on the PCB 1- and 2+ are connected together. (Flip over the board and you can see the trace). Then from 2+ to 2- it goes through string 2, 3+ to 3- goes through string 3. Then it gets a little weird. 4+ goes through string 4 then without coming back to the PCB it goes through string 5, then comes back to 4-.
                      1+ >> string1 >> 1- =[PCB]= 2+ >> string2 >> 2- =[PCB]= 3+ >> string3 >> 3- =[PCB]= 4+ >> string4 >> string5 >> 4-
                      • mrhappypants
                        • Aug 2015
                        • 8
                        • canada
                        #31
                        the only pins that power anything are 1+(power), 4-(controlled ground). So the scheme does work it just seems confusing at first.
                        I say "controlled ground" because it is actually the ground that is switched on and off to control the backlight.
                        • paulstef
                          • Dec 2013
                          • 724
                          Ok, so they are in series on the PCB for the first 4 strings and then 2 strings in series inside the panel. That answers my question. I have definitely open LEDs on string 1 :-|
                          Thanks!
                          • mrhappypants
                            • Aug 2015
                            • 8
                            • canada
                            #33
                            i started with one open LED i fixed it by bypassing with 5 diodes. I week later it blew a whole bunch short circuited. I have a feeling after one goes the whole damn thing goes to shit, but I'm hoping not.
                            when you find the one blown I would highly recommend putting about 20 diodes in series to limit the voltage strain on the LEDs. I am currently running mine with 12 LEDs burnt out and it's still lots bright (limited the current with resistors).
                            P.S. it's not that hard getting at the LEDs, just use a few butter knives and start at one corner. Slowly work your way around one clip at a time and use the knives to keep it separated as you go.
                            • paulstef
                              • Dec 2013
                              • 724
                              Maybe we could find out how the current limiting works and lower the LED current.
                                To reduce the current through the LEDs which will extend the life of the LED is to go to on screen user manual and reduce the backlights level.
                                • paulstef
                                  • Dec 2013
                                  • 724
                                  Since I believe the LED controller is a current controller, diodes in series or resistors will only help if the voltage from this controller is maxed out, otherwise it will just keep increasing the voltage in order to maintain the current through the LEDs at the level it's supposed to be. The right thing would be to lower current as Bud said via menu or electronically.
                                  I have 7 shorted LEDs, will try to replace just the diodes with some from spare strips from another TV.
                                  • longson90
                                    longson90
                                    • Jun 2014
                                    • england
                                    #37
                                    i have a samsung ue32f6200ak turns on with image on the screen and sound but no back lights
                                    • thoma
                                      • Sep 2012
                                      • 268
                                      http://allegro.pl/listwa-led-podswie...715483025.html
                                      http://mnogozip.ru/catalog/matritsy_...2ge-320sc0-r3/
                                      http://www.rempk.com/katalog/komplek...%28b/u%29.html
                                      d2ge-320sc0-r3 google a lot of informations !
                                      • thelmores
                                        • Feb 2011
                                        • 17
                                        #39
                                        This thread is about 1.5 years old, but I appreciate the information. I have bought some replacement LEDS, and am going to try and repair 3 bad strips out of 5.
                                        From what I can see in this case, the LEDS short, not open. Each strip I tested would light up, except for 1 LED on 2 strips, and 2 LEDS on the other strip. So the LEDs have to be shorted.
                                        Ordered 10 LEDs for about $25............
                                        http://www.ebay.com/itm/SAMSUNG-LUME...UAAOSwax5YnfL~
                                        Let you know how I make out when the LEDs come in in a couple weeks.....
                                        • x_orange90_x
                                          Samsung UA40J5200AK missing Smart features?
                                          by x_orange90_x
                                          I picked up this TV a couple days ago and it's SUPPOSED to be a smart tv, however it doesnt have any apps or wifi settings to change. I cannot find this EXACT model, it's actually a slight variant that is turning up this information. This is a UA40J5200AKXZN.
                                          The interesting thing about this tv is where it was made. It was made in Egypt. The closest information that I can find that could apply to this model is the following website:
                                          https://www.google.com/url?sa=t&sour...-ua-40j-n5200-...
                                          10-24-2024, 12:29 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
