Samsung UN32F5500 smart TV no backlight
  • kishorko
    • Mar 2015
    • 7
    The backlight of my 1 year old TV (Warranty finished) stopped working. Replaced PS board but that did not help. Opened the LED backlight panel and found 1 strip (out of 5 strips with 9 LEDs on each strip) not working. Because of not having experience, I ended with 2 entire strips burned out.
    LED driver output from PS board reading: 160 V, 320 mA
    Made custom LED arrangement (36 V and 240 mA) per strip using cheap 4.8 watt/meter led strip. The TV is working for 2 days (not uniform light though) but don't know when it burns again.
    1. Can anyone please help me finding replacement LED strips for UN32F5500afxza?
    2. Does anyone in this forum have spare parts?
    3. Can I find some suitable replacement surface mount LEDs ( I think 3.5 V, 320 mA).
    Thanks.
  • MagicSmoke
    • Feb 2011
    • 275
    Re: Samsung UN32F5500 smart TV no backlight
    There should be some kind of #'s on the strips that may help locate some replacements. Sometimes the same strips are used in other models.
    I had luck on a different set by contacting a seller on ebay that had other parts for tv I was working on for sale. He had the strips I needed just not posted. Managed to get a handful for cheap.
    Posting some pics of the strips may help also.
    • kishorko
      • Mar 2015
      • 7
      Attached are two pics of the main distribution panel and the number on a strip.
      There are 5 strips and each strip has 9 LEDs in series.
        Did you try contacting SHOPJIMMY to see what he has?
        • johnboy1313
          • Nov 2012
          • 1959
          You may be able to pick up a set on ebay with a cracked screen. Then you could sell the extra parts to recover the money.
          • kishorko
            • Mar 2015
            • 7
            No luck finding these strips neither in eBay, nor in Shopjimmy. Even, I am not finding any cracked screen TVs in ebay with matching LED strips.
            • mmartell
              • Oct 2013
              • 3189
              Some list these by the Panel number they came from.
              • MagicSmoke
                • Feb 2011
                • 275
                Is there a P/N on the led strips? Like the one on the connecting strip, the BN41 #.
                Found this here. Says you can special order? Maybe call them and see. Although I don't know for certain that is right P/N for your tv. Need complete model #.
                https://www.partstore.com/Part/Samsu...5300A/New.aspx
                • kishorko
                  • Mar 2015
                  • 7
                  There is a number but I dont know it is part number. It is D2GE-320SC0-R3[12,12,27].
                  I tried searching using this number and it brings many russian and chinese pages showing the correct strip.
                  • lfhlaw
                    • Mar 2014
                    • 102
                    I have the same TV with the Same issue. I've tried replacing the PSU and replacing the main board without any luck. I'm too lazy to part it out but this could help you. I'm not sure how to open it up more to get the strips out and I don't want to ruin them in the process. PM if interested and maybe we can work something out.
                    • kishorko
                      • Mar 2015
                      • 7
                      Ifhlaw, how do I do PM in this forum? I went to your profile but could not get any place to message you.
                      • lfhlaw
                        • Mar 2014
                        • 102
                        Hmmm...let me check my profile...I might not have a contact e-mail. there.
                        • lfhlaw
                          • Mar 2014
                          • 102
                          well I have a gmx.com account with the same avatar name. lfhlaw@.....so you can contact me that way. I think the issue is going to be shipping since well..i don't think you want the screen to break since i believe the screen works.
                          • lfhlaw
                            • Mar 2014
                            • 102
                            Does this TV have a Backlight Inverter? I had read somewhere that the Inverter was also on the Power Supply unit? Does anyone know?
                            • kishorko
                              • Mar 2015
                              • 7
                              It does not have a separate backlight inverter. The main power supply board suppies a dc power for the LED backlights.
                                This board?
                                http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
                                • JShively26
                                  • Mar 2015
                                  • US
                                  I have this exact same issue with the exact same TV. I have replaced the PS board and the main board and it Still has no backlight. My TV was purchased 1 year and 16 day before my issue started and samsung would do nothing but tell me a repair shop in my area or i could send it to them. I gave up and just purchased another TV
                                  • Paul K Smith
                                    • Jul 2015
                                    Can the LED strips be tested as a whole or must the LED buttons be checked individually?
                                    Do you have any insight on why the entire LED backlight system goes dark when a single strip or module fails? Are all the strips fed in series?
                                    • MagicSmoke
                                      • Feb 2011
                                      • 275
                                      Yes LED's are in series. Each led takes about 3v sometimes a little more volts DC. If one fails none will light up.
                                        For the 32 in it is more likely to be ONE big string.
                                        For example on this Samsung in the thread, it has one shorted LED, and one open LED.
                                        https://www.badcaps.net/forum/showthread.php?t=46403
                                        • x_orange90_x
                                          Samsung UA40J5200AK missing Smart features?
                                          by x_orange90_x
                                          I picked up this TV a couple days ago and it's SUPPOSED to be a smart tv, however it doesnt have any apps or wifi settings to change. I cannot find this EXACT model, it's actually a slight variant that is turning up this information. This is a UA40J5200AKXZN.
                                          The interesting thing about this tv is where it was made. It was made in Egypt. The closest information that I can find that could apply to this model is the following website:
                                          https://www.google.com/url?sa=t&sour...-ua-40j-n5200-...
                                          10-24-2024, 12:29 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
