Panasonic TCP42S30 SN Board reflow-Help out a noob!
  • WHaThEFLuX
    • Feb 2015
    • 277
    Re: Panasonic TCP42S30 SN Board reflow-Help out a noob!
    I'll check that now, how do I go about measuring ERC?
    Or I should say where is that located?
    I replaced 4 fets and their corresponding resistors along with transistor DG302, TW suggested I replace the driver as well, I believe it's IC502.
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
      The blue caps are the ERC voltage. Energy Recovery Circuit. Basically make a plasma panel much more efficient by extracting energy that would otherwise be wasted on every sustain cycle.
      My set (a TX-P42U30B, but same SN board) had bad IC502 and I think Q531 was suspect too. Initially got the soldering on them wrong - set would power up with a grey screen for 2s then shut down with 6 red blinks. Maybe try lifting Q441 and D481 - this will isolate the ERC path, the green LED should NOT light up and you should get a brief grey flash on the screen before the set shuts down. This would confirm the ERC path is the cause of your fault. It would also eliminate a panel problem. Don't try and power this up too many times as it will be stressing the SUS IGBTs (the ERC gives them an easy life, soft switching them...)
      • WHaThEFLuX
        • Feb 2015
        • 277
        Interesting, I replaced Q441 and D481, so I should lift them, reinstall the SN board and power on?
        -retiredcaps
          Yep, just see what happens, only try it a few times to see if you get that very brief priming glow. If you're REALLY lucky you might even get a brief "no signal" message before it cuts out
          • WHaThEFLuX
            • Feb 2015
            • 277
            Just checked the blue caps on the SS and SN again, on both of them one side reads 200 and the other side 100.....Should I still lift the components?
            -retiredcaps
              You need to measure -across- the caps, sorry if that was not clear. i.e. pos one end neg other end... it does not matter which way around pos/neg are,
              • WHaThEFLuX
                • Feb 2015
                • 277
                ok now I understand, measured across and got ~110 on the SS board and ~95 on the SN.
                -retiredcaps
                  Well your ERC circuit is working so I would try and figure out why the -VAD is low. Perhaps try lifting off the SUS IGBTs (up/down) and see if it comes back. Did you replace any of the driver ICs for ERC or SUS portion? (there are two drivers for each group of IGBTs...) Small little chips, pretty tricky to work with.
                  • WHaThEFLuX
                    • Feb 2015
                    • 277
                    I didn't replace any drivers, but to take us back to where we started, I assume when you wanted me to measure at -VAD you wanted me to across as well? When I do that I get 190, and VFG is 180.
                    -retiredcaps
                    • WHaThEFLuX
                      • Feb 2015
                      • 277
                      UPDATE:
                      After reflecting on why I've spent so many of my waking hours obsessed with this set, I decided to go over all my solder connections just to see if anything was amiss. Turns out Q441 had somehow come loose and was slightly lifted off the board. I touched that up and gave it one more shot. After power up the SN board made an awful buzzing almost hissing kind of sound, then out of nowhere, I got the no signal box on the screen! After about 15 seconds there was a pop and now I'm back to square one, however I know the panel's good!
                      So here's where I'm at; Q441, D481, Q451, and D461 are now all shorted. Do I order those components and try again or should I assume there's something else seriously wrong with the board?
                      -retiredcaps
                        So, the ER circuit went POP.. I suspect something is wrong with the little driver IC502/Q531... did you replace those? They fail about half of the time on this model.
                        • WHaThEFLuX
                          • Feb 2015
                          • 277
                          I did not replace those but I guess I'll order them along with two new DG302s, is there any way to test IC502 and Q531?
                          -retiredcaps
                            Yes, but given they cost so little I would always replace them anyway. They are tricky to replace though.
                            • WHaThEFLuX
                              • Feb 2015
                              • 277
                              I just ordered them, if you could tell me how to test the ones that are on the board that'd be great, apparently my reflow skills aren't as good as I thought. But I was able to find a working SN board for cheap, so even if I hack my board to pieces I'll still be able to get the set working.
                              Any tips on replacing them? Besides being accurate, it's pretty much just lifting the bad ones and dropping the new ones in right?
                              -retiredcaps
                                I would say, reasonably difficult to do if you've not done it before. Main issue is alignment. Getting them off is pretty easy. You need a good soldering iron which is temperature regulated (usually if it has a display or adjustment dial with a blinking LED, it's regulated) and steady hands. I use a jeweler's loupe to inspect the soldering before powering it up. Don't apply too much heat or you can damage the board which can make it a real pain to repair.
                                • WHaThEFLuX
                                  • Feb 2015
                                  • 277
                                  Sounds difficult but doable......sorry for being so persistent but I'd love to have a way of testing IC502 and Q531.
                                  -retiredcaps
                                    Test between pins 7 and 8 for Vcc to OUT short, and pins 3 and 7 for GND to OUT short for IC502.
                                    Test between pins 1 and 4 for top NPN short, and pins 2 and 4 for bottom PNP short for Q531.
                                    Does not eliminate possibility of internal, invisible damage, though...
                                    • WHaThEFLuX
                                      • Feb 2015
                                      • 277
                                      7-8 and 3-7 on IC502 are giving me ~1800, 1-4 on Q531 is ~1800 as well, and 2-4 is giving me ~80 and then steadily rising.......not sure what to make of it, when I get the new pieces I'll compare them.
                                      I'm confident in my abilities but there's a good chance that those components won't make it onto the board alive once I have my way with them. With that being said, should I attempt the IC/transistor swap or just throw the two new DG302s on again and hope for the best? Since I'm almost certain something is shorted would putting the DG302s on and firing it up definitely just pop them again?
                                      At this point it doesn't really matter since I've got a good board on the way. I've given it the good ole' college try and just want the set working, but I'm really determined to get my original SN board working or fry it trying.
                                      -retiredcaps
                                      • WHaThEFLuX
                                        • Feb 2015
                                        • 277
                                        If anyone's still with me, I lifted Q441 and D481, powered on and got the brief grey flash. Does this confirm beyond all doubt that the ERC path is indeed the problem and IC502 & Q531 need to be replaced? As I'm staring at them in my hand, I can't help but feel like they're about to become tiny melted globs of failure all over the board.
                                        Nevertheless, I'm not going down without a fight!
                                        If anyone can tell me what temp I should set my station at I'd really appreciate, 340°C seems to take forever but when I go higher things start to get a little crispy.
                                        -retiredcaps
                                        • WHaThEFLuX
                                          • Feb 2015
                                          • 277
                                          So IC502 and Q531 are on the board.
                                          I found these components to be easier than the the other ones surprisingly, except for their size, they came off and back on very quickly. I'm just waiting on the two DG302s to come in the mail then I'll be ready to fire her up again, anything I should look out for?
                                          -retiredcaps
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                            Having said that I come to the gist of my post on the forum as the title suggests.
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
