Samsung la55c750r2f - screen goes green then won't turn on
  • jimbojangles
    • Feb 2015
    • 5
    I've got a samsung la55c750r2fxxy LCD TV with a problem. After watching for a while, the screen briefly goes totally green (1 second), then goes black. The standby light goes off, but flashes red when you try turning it on again.
    If the TV is unplugged for a few minutes, it turns back on normally again, but the problem continues to happen.
    I've tried cleaning the ribbon cable, and I've replaced the 2 25v 1000uf capacitors on the power supply board, but the problem persists.
    All the capacitors appear fine, but I'm considering replacing the rest of them on the power supply board.
    Any hints, other than take it to Samsung?
    Thanks!
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsung la55c750r2f - screen goes green then won't turn on
    Pics of each board and one of entire layout please
    • jimbojangles
      • Feb 2015
      • 5
      Here are some pics - let me know if they're not adequate!
        • 12331
        • U.S.
        do you have a digital multimeter to test with?
        • jimbojangles
          • Feb 2015
          • 5
          I've got one but I've never used it before. I might need to watch some youtube to know what you do with it!
            • 12331
            • U.S.
            for sure, youtube has good tutorials, when your comfortable, let us know, we can help you test.
            • jimbojangles
              • Feb 2015
              • 5
              Right! Skills acquired! Now, what should I be measuring?
                • 12331
                • U.S.
                ok, check the connectors of power supply, the label is there by it, says 5v, 13v, 18v etc, looks like you can test from the back, the metal pins there, test with tv on, black probe to chassis, as always be careful working with power supply, HIGH VOLTAGE, on primary side can be deadly.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Its seems to be heat related, if you have a hair drier use it and heat the boards, especially the tcon and motherboard too see if heating one or the other speeds the timing of the fault up showing you what board is at fault.
                    • 12331
                    • U.S.
                    Thanks!
                    could be those other caps, at least they dont cost a lot.
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                      by JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                      Please help. Thanks in advance!
                      08-12-2025, 11:45 AM
                    • String2016
                      samsung np300e green screen
                      by String2016
                      I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
                      07-26-2025, 04:00 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • valvashon
                      Samsung UN60JU6500, stripe on left side of screen
                      by valvashon
                      Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
                      Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
                      Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
                      Thanks, Val
                      11-21-2025, 03:01 PM
