Sony 55hx823 4 Blinks
  • zomi
    • Nov 2011
    • 505
    Right has 55hx823 gives 4 blinks
    From cold sometimes works for 20 mins
    then its on and off
    Once you power it on again
    Leave it a little longer and It may play nice abit longer.
    Something not right..
    Not had the back off yet
    Just playing with it to see how it behaves..
    Previously it is supposed to have had the balancer board changed..
    Service manual is attached
    Just one thing if someone could help is
    what is the termonology sony use
    And the balancer board is the led board yeh ?
    B* board
    G* board
    led board
    Could ulitmately be a failed led but I am pzuzzled why at times it runs for 20 mins or so
    So hoping it a board issue ..
    Will open up tomorrow when I have some helpers and we can see what it does..
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Sony 55hx823 4 Blinks
    Open set and take pictures of boards and chassis please
    • freakaftr8
      • Oct 2012
      • 3743
      technically the balancer board is in a way the LED board although the power supply drives the LEDs directly I believe. However I had a TV similar to this and it turned out to be the balancer board. when an LED fails it fails it doesn't come back to life.however a balancer board can give a problem where the LEDs will work for some time and then just spontaneously go out.
      • zomi
        • Nov 2011
        • 505
        Will update with pictures later today if I can.
        Just waiting on helper to help dismantle.
        In the meantime..
        Led failure should be on/off cycle in a couple of seconds
        Even from cold ?
        What I have is works for 10 -30 mins then 4 blinks.
        then it will just flash on then off..
        Leave it to cool for 5mins then It will work again for 10-30 mins...
        • zomi
          • Nov 2011
          • 505
          here are some internet pics of the inisde of the tv
          and the led driver board
          its the same as the 46hx823 one.
            • 12081
            • U.S.
            could be bad capacitor/s on power supply.
            • freakaftr8
              • Oct 2012
              • 3743
              yep that picture on the right is the led balancer board and those driver ICs are known to fail like I said I've worked on a few of these now with the same problem they're very intermittent but if the LEDs light up then they are good.
              of course there is always a chance that you have a short in one of the wires that go to the LED backlights that run into the back frame behind the LCD panel. I've seen that too and that could present a problem as the TV starts to warm up things move in the wire touches ground. What happens when it shuts down with 4 blinks and you immediately disconnect the power and connect it back up and then power it up does it come right back on and play for awhile again? because if that's the case and it does come back on then that would blow my theory about the shorted wire
              • zomi
                • Nov 2011
                • 505
                No it does not come back on straight away.
                Have to leave it a while
                Then it works
                Had tested it at 5 min intervals
                After a few seonds wait it still blinks 4
                does that make sense..
                Just going to take the back off then wait till it fails then spray the driver ic.
                And see what happens..
                Are the driver ic's availble as it would make it easier and cheaper..
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have worked on an NX one and the ballancer board looks very similar, if not the same. The IC it was available, but the whole board it was $58 from shopjimmy and I couldn't way for three weeks, for the ICs to arrive from China.
                  There are test points at each IC, you could compare them and see which one is bad.
                  • zomi
                    • Nov 2011
                    • 505
                    thanks...
                    Just more one qu
                    once I remove the back off this tv
                    I Cant mount it back on the stand can I ?
                    going to have to rethink my work area..
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Yep that balancer board is identical to a kdl-55hx729 I repaired. It came on with perfect picture for 10 seconds them the bottom right would go out. After that 4 blinks. Like tibimakai said there are testpoints you can use to check each ic with the next til you find the bad one.
                      • zomi
                        • Nov 2011
                        • 505
                        Pictures
                        • zomi
                          • Nov 2011
                          • 505
                          Voltage at the fail point on the ic is 2.848
                          At cn6002 i have 2.79v
                          • zomi
                            • Nov 2011
                            • 505
                            At the test points near the 4 clips for the ribbon cables I have 29.84 across each one
                            • zomi
                              • Nov 2011
                              • 505
                              I tried the method with Tcon disconnected
                              and power on and plug in to create white screen
                              All whiteness is uniform
                              no indication of led gone out.
                              When turning on today it was on and off intermittently
                              Now I have released the tension clip on 2 /4 of the led cables its been working for
                              20 mins
                              no issues..
                              If it works for min or 2 then turn off for few secs its back on for a min or 2..
                              @freakaftr8 i think that rules out cabling ??
                              So not sure at moment what issue is
                              • zomi
                                • Nov 2011
                                • 505
                                Now with the back off
                                And the heatshield off the led board
                                And the tension off on those 2 mentioned clips
                                been running now for
                                1hr 20
                                no issues
                                • zomi
                                  • Nov 2011
                                  • 505
                                  Still going strong no issues
                                  Stranged indeed...
                                  • zomi
                                    • Nov 2011
                                    • 505
                                    Ran for 5 hours then turned off
                                    I decided to start touching the led driver...
                                    thought maybe the cables...
                                    Its up and runing again and no amount of putting pressure on the led cables will make it turn off...
                                    really puzzling
                                    • zomi
                                      • Nov 2011
                                      • 505
                                      As you can see leds themselves seem to be fine..
                                      • zomi
                                        • Nov 2011
                                        • 505
                                        Had enough for today
                                        Have took bl error signal to ground on the psu side..
                                        Will see tommorrow if it brings any thing useful...
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • huj3r
                                          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                                          by huj3r
                                          Hi there!
                                          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                                          Photo of the situation after the black shadow dissipates:
                                          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                                          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                                          > This indicates HFR Communication error. [ HFR Communication...
                                          08-15-2023, 10:55 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • delpiero3
                                          Sony Vaio SVS MBX-261 board failure
                                          by delpiero3
                                          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                          Nevertheless, let's say, i don't come as a total beginner.
                                          I have this old laptop, which suit perfectly my needs, with the...
                                          10-29-2024, 06:16 AM
