Sony 55hx823 4 Blinks
  • zomi
    • Nov 2011
    • 509
    Re: Sony 55hx823 4 Blinks
    Right with bl error grounded.
    Its not turning off no more, lol
    But nothing noticeable is happening..
    No sudden dimness or anything like that..
    • zomi
      • Nov 2011
      • 509
      Update ater 1 day of full use with bl grounded.
      Runs fine in current state..
      no issues at all with backlight or anything
      Volatges on the led driver board are perfectly fine after a days full use..
      • nomoresonys
        • 12274
        • U.S.
        is curious, could be with back on something is overheating maybe?
        • zomi
          • Nov 2011
          • 509
          Even with back off soon as i reconnect the bl error cable it starts again
          with the 4 blink cycle...
          Have had the heatshield plated connect to the led driver board today.
          And it runs fine too..
          Anyway going to put the back on tomorrow and connect the bl signal to ground properly
          its just taped to the chaisis at the momnet lol...
          Quite a strange senario..
          • zomi
            • Nov 2011
            • 509
            Update
            Tv works fine
            Is not showing any issues visually, no sign of any led being out or anything
            So will be putting the back on and use as is...
            Not the best conclusion but the tv works fine
            had about 36 hours use now..
            I still think a minor component is not quite right, either on the led driver or in the
            path of the error circuit it self causing a false error code maybe... ?
            • freakaftr8
              • Oct 2012
              • 3743
              It is possible to have the main board throw erroneous error codes for no reason. I have an 80 inch sharp LED TV that will not power up if its been unplugged I get the 1-1 code but if i bypass the code when I plug it in it never has a problem until I get some plugin so I know that one is definitely a main board problem
              • nomoresonys
                • 12274
                • U.S.
                #27
                80 inches? holy cow, I bet the mainboard is pretty pricey.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Actually it is of a rare earth material called unobtanium. If found hold onto it with dear life! Lol
                  • nomoresonys
                    • 12274
                    • U.S.
                    #29
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • huj3r
                      Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                      by huj3r
                      Hi there!
                      I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                      Photo of the situation after the black shadow dissipates:
                      After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                      I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                      > This indicates HFR Communication error. [ HFR Communication...
                      08-15-2023, 10:55 AM
                    • jb_Bak
                      by jb_Bak
                      CN6401
                      Pin 01 NC
                      Pin 02 NC
                      Pin 03 "BL_ON": 0V
                      Pin 04 "N/C"
                      Pin 05 "STBY 3.3V": 3.5V
                      Pin 06 "GND": N/C
                      Pin 07 "AC_OFF"...
                      09-27-2021, 04:52 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
