M3D421SR main board replacement
  • twoj
    • Feb 2015
    • 25
    I can not find a new mainboard for this TV, its # is: TXBCB2K00603Q.
    Does anyone know its 'brother': #TXBCB2K00605Q would give me a problem?
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Re: M3D421SR main board replacement
    Google the part number...
    • twoj
      • Feb 2015
      • 25
      I did, but I can not get a confirmation that this other part (5Q) will be exact replacement for (3Q). I received conflicting reports, one seller said that they are not compatible and another said that they will be fine.
      TXBCB2K00605Q is listed as a part that goes into M3D421SR, I'm just looking for some clarification (since Vizio does not provide any) from the field to make sure this will work.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        A quick search on Ebay and i found that the boards below are for the M3D421SR model…..
        CBPFTXBC2K00601Q
        CBPFTXBC2K00602Q
        CBPFTXBC2K00603Q
        CBPFTXBC2K00604Q
        Did you compare them visually? It could be that 1 model is used for example a different country?
        • twoj
          • Feb 2015
          • 25
          I do not have the new 5Q board yet. So no visual comparison is possible yet.
          I looked all over, and no-one has a new 3Q in stock (but that one post on ebay #321476068404, board is 'used').
          I was also unable to find any further reference to the different flavors of the TXBCB2K0060XX. One seller said that as long as the the first set of number is: CBPFTXBC2K006 it should work, however another said that it will not.
          I ended up ordering a 'new' 5Q board, well see how it works when I get it. Trial by fire! :-)
          But, if anyone has any explanation to what these number signify, that would be great!
          Regards
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Its not a problem that the board is used? Im thinking that these boards have minor differences.
            You could have googled for images of the 5Q board and compare it to yours
            good luck and let me know if the board works or not.
            • twoj
              • Feb 2015
              • 25
              From what I saw in the pics, I could not find any differences. Maybe I missed something.
              I was hoping to find manufacturer's x-ref sheet, but I think I may be dreaming here.
              I will definitely post back as to how it goes. It may help out the next guy.
              • twoj
                • Feb 2015
                • 25
                Here are my 2 board, I can not see any differences to my untrained eyes.
                Anybody care to take a quick peek?
                • twoj
                  • Feb 2015
                  • 25
                  OK! I got the new board and I replaced it.
                  IT WORKED! :-)
                  Thank you and good luck! If anyone is interested in my old CBPFTXBC2K00603Q let me know.
                  • tvquestions
                    • Aug 2015
                    • 3
                    • usa
                    Hey, I see that you replaced your main board with the 5Q. Is it still in working order?
                    • twoj
                      • Feb 2015
                      • 25
                      Working Great!
                      No problems at all! Got lucky this time.
                      • ecking767
                        • Oct 2009
                        • 492
                        This fix can help some with bad firmware, I can't find any information on the other board part number matching or being compatible with the M3D421SR
                        http://www.ernestos-electronics.com/...re-update-fix/
                        • twoj
                          • Feb 2015
                          • 25
                          ecking767, this fix might work if your board is semi-fried; however my was partially working.
                          TV was functional, with the exception of HDMI signal inputs. All other inputs worked, including VIZO apps.
                          • ecking767
                            • Oct 2009
                            • 492
                            You will be surprise on how a bad Firmware can effect a main board. not just stuck on logo or not powering on problem. other problem like no picture and missing HDMI ports. Its a very importance part on a main board
                            • twoj
                              • Feb 2015
                              • 25
                              So the firmware on these can get corrupted?
                              Have you ever seen it corrupt the HDMI inputs only?
                              • tvquestions
                                • Aug 2015
                                • 3
                                • usa
                                twoj, Thank you! I am trying to find the 5Q online and can't seem to find it. Could you tell me where you ordered yours from?
                                • twoj
                                  • Feb 2015
                                  • 25
                                  I go mine on ebay. Seller was: usblu_ray626
                                  Contact him to see if has any more.
                                  OR try to reflash the firmware @ $35 seems reasonable.
                                  BTW, what is the problem with your TV?
                                  • tvquestions
                                    • Aug 2015
                                    • 3
                                    • usa
                                    Black screen. Won't turn on, but Vizio logo lights up when connected to a power source. I took it to the repairman, but he can find the part (main board) anywhere, so I thought I'd offer to help look (that way I wouldn't be charged markup on the part as well.
                                    • twoj
                                      • Feb 2015
                                      • 25
                                      I'd try ecking767 fix above... for $35 you can not beat it... I do not know enough to say it will/will not work, but $35 is a small price to find out.
                                      Keep looking on ebay, and I would try other number as well 3,4,5,6 in the series...
                                      • ygorsan
                                        by ygorsan
                                        🧩 Problem Summary:
                                        • I
                                        07-28-2025, 08:34 AM
                                      • jb_Bak
                                        by jb_Bak
                                        CN6401
                                        Pin 01 NC
                                        Pin 02 NC
                                        Pin 03 "BL_ON": 0V
                                        Pin 04 "N/C"
                                        Pin 05 "STBY 3.3V": 3.5V
                                        Pin 06 "GND": N/C
                                        Pin 07 "AC_OFF"...
                                        09-27-2021, 04:52 PM
                                      • JDC
                                        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                        by JDC
                                        ONN 100012588
                                        Issue: No Power, Then Rebooting After Main Board Change
                                        Short answer: replace main board and power board
                                        Technical answer: replace main board and Q306 & Q307 on power board.
                                        Long answer:
                                        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                        07-15-2022, 07:39 AM
                                      • tuner2000i
                                        Philips 65PUS8518/12 distorted image after main board replacement
                                        by tuner2000i
                                        hello everyone,
                                        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                        07-15-2025, 01:15 PM
