Samsung LE32M51B S black screen
  • intenzive
    • Nov 2012
    • 27
    • Bulgaria
    Re: Samsung LE32M51B S black screen
    On the input side of the CP101 I have 0.24V WTF?! Soldering a temporary bridge on the CP101 didn't do the work.
    • intenzive
      • Nov 2012
      • 27
      • Bulgaria
      So do you get the 12V on the input side of the fuse? The TV is on when you make the measurement?
      If there is no 12V on the input side of the pin then the main board is not sending the Voltage to run the T-CON.
      I have this Tv and I found the fuse to give a reading of about 70 ohms, simply removing it and replacing with a temporary solder bridge rectified the issue, I'm not saying this will help you but your symptoms are pretty much what I was having.
      The blue s/n sticker to the left of the LVDS connector looks melted on one end, is there anything obvious around that area?
      It looks melted because I reballed this part of the PCB.
      • Dang
        • Aug 2013
        • 440
        I think you would have to say, if you have 0.25v @ V-in and 0.24v on the input side of the fuse, then this may point to an output problem with the main board, try to find which pins output the 12v feed and take some measurements, with both the LVDS cable connected and disconnected, let us know what you find, some close ups of both the front and rear of the main board would be useful.
        • Dang
          • Aug 2013
          • 440
          Just out of curiosity, what was it that you reballed and why?
            • 12081
            • U.S.
            maybe try a different mainboard.
            • intenzive
              • Nov 2012
              • 27
              • Bulgaria
              #26
              I am stuck guys... obviously the mainboard is not sending 12V to the T-CON... I did some measurments from the mainboard to the T-CON and the voltage is 0.24V. Do you have any idea what can cause the problem?
              I was hoping there is a loose connection on the T-CON. That is why
                You will need to locate the switched MOSFET that supplies the 12V to the T-CON fuse when the processor sends out the on command to turn on the switched MOSFET.
                We will need really really good clear pictures around the LVDS connector on the main board to see if we can locate the MOSFET.
                You should also try removing the LVDS cable from the main board and check and see if the power pins on the LVDS will have 12V.
                You can also check the resistance between the chassis and the T-CON fuse to see if it shows very low resistance.
                • intenzive
                  • Nov 2012
                  • 27
                  • Bulgaria
                  #28
                  OK. Here are some good photos of the mainboard near LVDS connector front and back:
                    What is the P/N of that IC 805 to the right of the LVDS connector?
                      • 12081
                      • U.S.
                      #30
                      looks like you have 5 fuses there by the connector, did you check those?
                        Those 5 'FT' are Ferrite beads.
                        • intenzive
                          • Nov 2012
                          • 27
                          • Bulgaria
                          #32
                          Originally posted by budm
                          what is the p/n of that ic 805 to the right of the lvds connector?
                          ic 805 - 9933b w548
                            MOSFET FDS9933.
                            Put the LVDS cable back in place then check the resistance between either end of the SMD fuse on the T-CON against pin 1 through pin 8 to see if any one of those pins have direct connection to the fuse on the T-CON.
                            • intenzive
                              • Nov 2012
                              • 27
                              • Bulgaria
                              #34
                              MOSFET FDS9933.
                              I have direct connection between the fuse on t-con and the MOSFET on pins 7 and 8 on both sides of the fuse.
                                • 12081
                                • U.S.
                                #35
                                oh, ok, didnt think they looked like fuses.
                                • intenzive
                                  • Nov 2012
                                  • 27
                                  • Bulgaria
                                  #36
                                  Oh, and someting else I measured the voltage on pins 1 and 2 and it's around 6.35V if this matters. On pins 7 and 8 which are directly connected with the fuse on the t-con I have the same voltage 0.24V
                                    OK so that FDS9933 DUAL P-CH MOSFET, and it is the switched MOSFET for feeding the B+ to the T-CON.
                                    You also need to take the reading without the LVDS cabel connected to the T-CON to see what you have on pin 7/8 (Drain D2).
                                    I need Voltage reading of all 8 pins when TV is OFF and when TV is ON.
                                    Per spec sheet of the LCD panel LTA320W2-L03, the typical DCV for the T-CON is 5VDC.
                                    • intenzive
                                      • Nov 2012
                                      • 27
                                      • Bulgaria
                                      #38
                                      Well finally I took the measurments as you adviced me to do and here are the results:
                                      • intenzive
                                        • Nov 2012
                                        • 27
                                        • Bulgaria
                                        #39
                                        up
                                          Originally posted by intenzive
                                          up
                                          What does that mean?
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • arbitarytwist
                                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                            by arbitarytwist
                                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                            03-01-2025, 01:16 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • totof
                                            Samsung UE50KU6070 black screen
                                            by totof
                                            I have my TV model UE50KU6070 which I am trying to repair.
                                            BN41-02528A / BN94-10800C motherboard.
                                            If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                            When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                            After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                            09-26-2022, 02:34 PM
