Toshiba 32w1333d - Flashing red/green standby light
  • zomi
    • Nov 2011
    • 509
    Re: Toshiba 32w1333d - Flashing red/green standby light
    any one looked into this
    https://www.youtube.com/watch?v=6SpUzP-_JPo
    http://electronicshelponline.blogspo...-software.html
    maybe of use ?
      Don't think it applies for these newer sets, they use USB only for update.
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        Originally posted by tom66
        Publicly available from Toshiba, I mean....
        http://www.dl.toshiba.com/DLY/index....ion=GB&lang=EN
        Hi Tom. I am looking the bios/firmware to download as I am having that same issue. Is there another link as the above does not work?
        EDIT
        Never mind. It now works.
        Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
        • sordids999
          • May 2013
          • 2160
          hello guys did anyone ever solve the problem with this tv ?
          i have the same fault Flashing red/green standby light but i end up with a solid green light
          with sound also but no picture
          • sordids999
            • May 2013
            • 2160
            im not sure mine if mine is software related i have already tried the usb update using the OK on the remote but no luck !
            i have also noticed the power lead going from the psu to the backlight panel starts at 95 volts but drops gradually
            • sordids999
              • May 2013
              • 2160
              #26
              if i shine a light on the panel i can see a message saying no channels have been added yet and strangely it upside down ?
              • sordids999
                • May 2013
                • 2160
                #27
                right i can basically use the tv menu but upsaide and no backlight i have tried a factory restart but still the same
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  Well Sordids999 I have fixed lots of these crappy Led Tvs. As the voltage starts then collapses you have a failed Led with in the Lcd module. Tear apart the panel and get some images of the strips should be 2 strips with 22 Led in total.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Btw be very careful when taking this apart the Lcd glass is so thin meaning it cracks very easy and the front bezel is the support for it so when you remove the front bezel the Lcd isnt supported.
                    • sordids999
                      • May 2013
                      • 2160
                      #30
                      https://www.youtube.com/watch?v=_uO94lBkSEE
                      yeah im thinking the same until i saw this just an idea i might have the same fault
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Yeah but your backlight is out not intermittent ? The supply briefly fires but then shuts down. I would recommend you take the panel apart first check this out:
                        https://www.badcaps.net/forum/showth...ghlight=Ves315
                        • sordids999
                          • May 2013
                          • 2160
                          #32
                          Right so it seems the to has two faults Led and software due to the screen upside down ?
                          Are the LED easy to source ?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            You can replace the actual bulbs they are easy enough to source from sashed screen Tvs if not you can easily substitute them.
                            • sordids999
                              • May 2013
                              • 2160
                              #34
                              The confusing part is that i have flashed the main board with latest firmware but still the screen is upside down so the only option i can see to correct this is a replacement main board ?
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #35
                                That is weird, I think there is an option to rotate the screen is the SM.
                                • sordids999
                                  • May 2013
                                  • 2160
                                  #36
                                  in service menu ? menu 4725 ?
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #37
                                    Yes buddy, firstly need to try and fix the backlight.
                                    • sordids999
                                      • May 2013
                                      • 2160
                                      #38
                                      Right so finally stripped the panel down but does anyone know the best way to test the LED`S ?
                                      thanks
                                      • sordids999
                                        • May 2013
                                        • 2160
                                        #39
                                        And im not convinced the LED`S are at fault if i disconnect the LED strips and measure voltages going to the strips im getting the same again voltages starting high then dropping gradually
                                          The Voltage will rise up to high level util trip point is reached (it is constant current source so Voltage is varied to maintain constant current through the load), there is protection circuit to shut down if no load is not connected or open load condition.
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • 7ony
                                            Samsung plasma - flashing standby light
                                            by 7ony
                                            The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                            Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                            Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                            No visible...
                                            08-31-2020, 05:18 PM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • naddaw000
                                            Toshiba 55U7863DG - green light blinking (17MB130S)
                                            by naddaw000
                                            Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                            I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                            12-02-2023, 01:35 PM
