lower voltage caps
  • gobby009
    • Oct 2014
    • 63
    • uk
    lower voltage caps
    i have a tv power supply with a bad 330uf 25v cap on it.can i change it for a 220uf 25v or a 470uf 25v?just dont have any 330 caps
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: lower voltage caps
    470uf 25V would be my first choice, if I only had those 2 to choose from. You can go higher in voltage too, if you have some.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      ^^^^^^and me^^^^^^
      • lookimback
        • Aug 2013
        • 1489
        Just for testing, I've used 2 in parallel to equal near the correct capacitance. Or, as CapLeaker said, higher voltage if you have that. Lower voltage could pop.
        ------------signature starts here------------
          It is risky, sometimes changing the capacitance can destabilise the circuit, so you need to be careful, I would use 470uF over 330uF if you have to. Make sure to use good high quality caps.
          • mmartell
            • Oct 2013
            • 3189
            Tom I think you meant 470uf over 220uf ?
