Electronics failing when supplied with lower voltage
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    recently I watched Richard's video on YT (Learn Electronics Repair channel) with an explanation why lower input voltage than rated can also kill electronics components.
    The vide can be shown here.
    Now, I would like to learn more and I'm not sure that I understood exactly why this is happening.
    It is clear to me that PWM chip will keep MOSFTES switched On longer (duty cycle is longer) and that they will dissipate more heat. I think this is not the main reason because MOSFET can probably work switched on for a long time. It is also possible that output coil will go into saturation. But why if coil goes into saturation current will go up?
    I know for sure that electronics components die because of the higher current and higher voltage with the same resistance will cause higher current.
    But how exactly lower voltage will cause higher current because of the longer duty cycle?
    Thank you.
    Merry Christmas and Happy holidays to all!
  • samoelec
    Trying to understand how to find best replacement cap for old parts.
    by samoelec
    Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
    Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
    The power supply board is exactly the same from this post so I'll just steal it for now.
    I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
    04-01-2024, 03:39 AM
  • Hypersapien
    Artist seeking to tinker with electronics safely
    by Hypersapien
    Howdy folks! I'm an artist in the video game industry, and my job entails making a lot of mechanical and sci fi assets. I thought it might be a good practice to start disassembling some electronics to be more familiar with how real electronics are manufactured and assembled, which is how i found my way to these forums.
    When I started researching what tools I might need, I quickly encountered the warning "Some devices can maintain a potentially lethal charge in their capacitors, even up to years after last being powered on", which was enough of a scary thought for me to...
    10-22-2023, 01:31 PM
  • quickname
    Cyberpower 1500AVR UPS repair
    by quickname
    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
    I decided to verify that the batteries were...
    11-12-2023, 09:57 AM
  • mscottdoran@gmail.com
    Can anyone identify the classification of this data signal?
    by mscottdoran@gmail.com
    Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
    The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
    The boards are powered by a ground referenced...
    02-08-2025, 11:31 AM
  • Bugmanscj
    Audio Linear Power Supply (LPS)
    by Bugmanscj
    Hi: Found this forum fumbling over the net looking for replacement capacitors for a high quality 2uv ripple model Kaia, Core Audio Technology LPS. I bought it used on fleabay and figured I would have to recap and sure enough one of the 22,000uf 35V 105c caps is bulging. These supplies were made briefly around 2014 for MAC Mini audio servers, and were quite costly at the time ($1.7k), you know it's audio... I will use it for a video processor power supply to replace a switched version. I figure it's a low cost attempt to see/hear what difference it might make in my system. Plus I get to learn...
    02-17-2025, 08:50 AM
