Operating caps well below rated voltage
  • Perry Babin
    • Apr 2024
    • 22
    • usa
    I think this has been answered but I couldn't find the thread.
    Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
    So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
    If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
    Or would it require reforming?
  • andrewsawesomr
    • Jun 2022
    • 101
    • United States of America
    Operating caps well below rated voltage is fine, however, over time the cap will need to be slowly risen up to its rated voltage if you want to use it at the rated voltage again.
    • Perry Babin
      • Apr 2024
      • 22
      • usa
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8339
        That depends on how much below rated value you go.
        For shits and giggles let’s say you use a 200v cap and only have 12v on the rail, that is not a good idea. 25V cap on a 12V rail, is perfectly fine.
          • Jul 2011
          • 6069
          For shits and giggles let's say you use a 200v cap and only have 12v on the rail, that is not a good idea. 25V cap on a 12V rail, is perfectly fine.
          What is the best practices should you follow when using a capacitor voltage values because in rare occasions I will use a capacitor with a voltage of 50 volts on a 12 volt switching power supply circuit
          I guess this is a valid topic to discuss with what would be an acceptable general rule of thumb to follow
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8339
            sam_sam_sam
            I go by the rule of roughly double the voltage rating vs what the voltage rail is. However this doesn’t work 100% of the time, because of size etc… and also depends on what circuit.
            A different problem is when you need caps in stock. Mostly I have 50V caps but I also have common capacities in 25V format. Then I got a very few odd 63V caps that I need occasionally. Primary filter caps I don’t stock period as they are rather expensive. Weird or large capacities I usually order. The brands I use are Panasonic, Nichicon, Rubycon and very seldom a 4th brand all are 105C rated and order them from a trusted supplier, not eBay or AliExpress etc. So far so good, never had a return of any of my capacitors that I put in fail yet.
            • UserXP
              Transformer producing higher voltage than rated
              by UserXP
              Hello, people.
              i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
              So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
              09-02-2025, 12:42 AM
            • Fernon@Repair
              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
              by Fernon@Repair
              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
              VCCIO voltage ok
              VCCSA Voltage OK
              VCCPLL Voltage OK
              Ram Voltage ok
              RamVTT OK
              VPP 2.5 OK
              But No Core Voltage
              and i want to this vrm ic datasheet or pinout (ISL69269)
              anyone have this ic pinout voltages?...
              06-25-2025, 07:19 AM
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
              Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
              I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
              The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
              Now...
              06-09-2024, 10:57 AM
              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
              Based on Intersil's Robust Ripple Regulator...
              11-05-2024, 03:24 PM
