KDL-32EX653 ldvs t-con cable connector
  • holmzy
    • Nov 2009
    • 99
    please help i cant seem to figure out how to open this. i have already damaged it.
  • holmzy
    • Nov 2009
    • 99
    Re: KDL-32EX653 ldvs t-con cable connector
    see attached
    • holmzy
      • Nov 2009
      • 99
      help please
      • holmzy
        • Nov 2009
        • 99
        anyone? any ideas? i can provide more pics
        • nomoresonys
          • 12145
          • U.S.
          not a clue but more pics. maybe from different angles, couldnt hurt.
          • holmzy
            • Nov 2009
            • 99
            see attached
            • splitcrete
              • Dec 2012
              • 387
              • usa
              I think I would try to swivel the red circled tabs out. Not Sure so be easy.
              • anmol
                • Mar 2012
                • 73
                • India
                Press down white tab at same time and pull back cable .
                wbr
                • holmzy
                  • Nov 2009
                  • 99
                  Hi thanks for the replys @splitcrete you cannot swivel it. the two white pieces were connected in the middle before i broke it. @anmol i was trying that but it didnt freely come out but that was the only logical solution. do you know for sure if that is the method? thanks again guys.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    Yes I'm thinking the same , try to pull it down! It must be "easy" to remove these cables , if this does not work try to pull it up.
                    Its hard to see as you broke it off haha.
                    • holmzy
                      • Nov 2009
                      • 99
                      finally! I decided to be brave. go hard or go home! pushed down with scissors and yanked it out, it fought back with vengeance but then gave in and poped out due to my sheer biscep strenght!
                      cheers guys
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Haha , and how long you been staring at that connector?
                        • holmzy
                          • Nov 2009
                          • 99
                          only a week!
                          fixed the tv in 5 minutes. basically it had backlight no image. then on the board a saw a X-Reality chip, now coming from a gaming background i knew that chip had a failed ball joint. 2 minutes of a heat gun TV working! and yes the delay was the connector as i suspected before it had a bad connection. love fixing sony's!
                          • nomoresonys
                            • 12145
                            • U.S.
                            Originally posted by holmzy
                            only a week!
                            my truck has a bad ball joint, Ima try that heatgun trick on it.
                            • holmzy
                              • Nov 2009
                              • 99
                              hahahahhaa
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • Tomylee
                                No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                                by Tomylee
                                Sorry for the person who’s going to read all this !
                                I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                                While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                                During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                                07-11-2025, 11:52 AM
                              • x_orange90_x
                                TCL 50S535 bad tcon or panel issue?
                                by x_orange90_x
                                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                03-29-2025, 11:02 PM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • Ublala Pung
                                Lenovo V15 and V17-IIL and probably others with 10th or 11th gen CPU suffer from a design flaw
                                by Ublala Pung
                                The Lenovo laptops V15 and V17-IIL with I5 or i7 CPU and probably many other Lenovo laptop from this time with 10th or 11th generation Intel CPU suffer from a design flaw regarding the display/camera/microphone connector on the motherboard which is badly placed and the cheapest of the cheap connectors imaginable. As the cable is too near to the display and the connector does not fix it proper in place the cable develops little defects and those over time lead to a plethora of possible quirks or failures starting from the named RAM problem or sudden switching off in special when the display is...
                                04-23-2025, 04:47 PM
