bush LCD32TV005HD help
  • gobby009
    • Oct 2014
    • 63
    symptoms: turn tv on and the picture gradually goes brighter and brighter,open tv menu and the menu picture is fine.
    diagnosis: opened tv and found the cable connected to the mainboard from the inverter had 2 totally burnt out loose cables as pictured in picture 1 below.connected a new inverter cable but problem still exists.not sure how long those cables burnt loose.could the burnt loose wires have damaged the inverter?looked at the power supply and spotted 1 bulging capacitor in picture 2 below.what are the chances of this capacitor being the problem?
    any help would be appreciated.
  • selldoor
    Slow Learner
    • 7870
    Re: bush LCD32TV005HD help
    That capacitor is bulging change it for a good quality Panasonic FR or FM
    Chances are caps of a similar brand/series will also be going bad.
    Maybe also capacitors on the inverter - really need pictures of whole boards
    • gobby009
      • Oct 2014
      • 63
      hi thanks for the reply cant see any other bulging caps and dont have a meter with capacitor readings on it.but here are a few pictures of the boards.
      • selldoor
        Slow Learner
        • 7870
        OK well the nichicon caps on the inverter board should be ok I guess all you can do is to
        change the known bad one and see if it helps. Check the pins are clean in the socket where the wire burnt and that they are well soldered to the board ( we have seen sometimes where pins have just been sat loose in the board!! )
        Run it on test and check how hot the wires get. Finally give it a good dust down ( with the power off helps keep it cool though if its as cold as it is here that should not be a problem )
        • gobby009
          • Oct 2014
          • 63
          do you think that 1 bad cap could be the cause of the problem?????
          • selldoor
            Slow Learner
            • 7870
            Not a clue - is the cap next to the where the fault was - what value is the cap more likely the plug was not inserted fully into the socket or the cable could have been faulty - I cant see what voltage it was carrying or on how many wires sometimes if the current is high they have 3 or 4 wires carrying 12v or 24v. Is the Dimming control wire in the same cable
            trace it back/forward and see what components might have been damaged if the dim was shorted to the 12/24v. May be voltage regulator?
              Cables burnt like that are due to poor contact between the header and female socket, it has contact resistance which will heat up and burn. There is only one connector on the inverter board, that cable should go to the power supply board which supplies 24V at about 5A of current, I do not thing the cable will go the the main board. I cannot tell since we do not have the pictures of the whole back side of the TV.
              • gobby009
                • Oct 2014
                • 63
                the cable from the inverter board goes to the main board not the power supply and i replaced the burnt out cable but the problem still occurs.
                • gobby009
                  • Oct 2014
                  • 63
                  gonna replace that cap on the power board see if it is the culprit
                  • gobby009
                    • Oct 2014
                    • 63
                    just noticed this ribbon cable that connects the tcon board to the screen and its looking a bit faded could this be part of my problem?
                    • selldoor
                      Slow Learner
                      • 7870
                      I would not have thought so you can try removing and cleaning and test it for shorts/open
                      If replacing the cap doesnt help post good clear pictures of the sockets at each end of the burnt cable.
                      • gobby009
                        • Oct 2014
                        • 63
                        checked the sockets the burnt cable came out of and they look fine no corrosion,no scorch marks and theres no movement in them on the board.
                        • gobby009
                          • Oct 2014
                          • 63
                          ok so replaced the bad cap on the power supply abd the problem is still there here are some pictures of the fault.
                          • gobby009
                            • Oct 2014
                            • 63
                            selldoor i see your in the uk.do you repair tvs? just wondering if i could send you the tcon board to fit a new as15-f chip on it as i dont posess the soldering skills required.think the chips only cost a couple of pounds on ebay.or if anyone else from the uk could do it.
                            • selldoor
                              Slow Learner
                              • 7870
                              Sorry - no can do - I dont have the equipment or the skill/eyesight.
                              • willis6732
                                Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
                                by willis6732
                                This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
                                Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
                                The Driver board looked pretty toasty in the LED Driver Area.
                                So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
                                12-17-2024, 04:09 PM
                              • Tr0ll
                                by Tr0ll
                                Original T-con:
                                First replacement T-con:
                                10-07-2023, 07:48 PM
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • valvashon
                                Insignia NS-LCD19-09 (third and final post, hopefully!)
                                by valvashon
                                I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
                                Problem was no cold startup; it would only startup when you applied a heat gun to the board....
                                10-22-2025, 12:33 PM
