Sony KDL-46W4000 (2 blink code)
  • funtastic
    • Nov 2012
    • 63
    • New Zealand
    Re: Sony KDL-46W4000 (2 blink code)
    Sorry I'm new to testing a resistor, how should I test it? Probes either side on 200 ohms?? This is the resistor correct? Just would hate to do something wrong.
      • 12276
      • U.S.
      https://www.youtube.com/watch?v=cZFZc2r7aCM
      • funtastic
        • Nov 2012
        • 63
        • New Zealand
        Put multimeter on 200 ohms and it measured 3.6 then dropped and fluctuated between 2.7 -2.2
        • funtastic
          • Nov 2012
          • 63
          • New Zealand
          With the switch activated it's reading 1.6
            That is correct.
            No power APPLY to the TV.
            Set meter to 200 Ohms scale, then touch the two probes of your meter together and note the reding, then put the probes on the two legs of the resistor, the display should show about the same as when you touch the two probes together (<1 Ohm).
            • funtastic
              • Nov 2012
              • 63
              • New Zealand
              #26
              Touching the two probes together is 1.4 - 1.6 and on the resistor it's 1.9 -2.0 with no power
                OK, the resistor is not bad, so now we will need to look deeper in the 12V power supply section, that will be tomorrow.
                • funtastic
                  • Nov 2012
                  • 63
                  • New Zealand
                  #28
                  I appreciate it.
                  How do you find the time to help out so much with everyone?
                  • funtastic
                    • Nov 2012
                    • 63
                    • New Zealand
                    #29
                    just when you're able to help again Budm that would be great.
                    • funtastic
                      • Nov 2012
                      • 63
                      • New Zealand
                      #30
                      anyone want to continue helping please?
                      • funtastic
                        • Nov 2012
                        • 63
                        • New Zealand
                        #31
                        Help please
                        • funtastic
                          • Nov 2012
                          • 63
                          • New Zealand
                          #32
                          • funtastic
                            • Nov 2012
                            • 63
                            • New Zealand
                            #33
                            anyone?
                              OK, sorry I did not see the post, it is usually shows up in BOLD for the thread that I have not read yet.
                              You need to remove C6111 (0.018uF 1000V) and find out if the capacitance is still within the spec., the cap should be around transformer T6100 for the 12V power supply.
                              Also check R6120 (0.22 Ohms 2W).
                              • funtastic
                                • Nov 2012
                                • 63
                                • New Zealand
                                #35
                                Thank you for your reply.
                                Do I need to get an ESR meter to test the capacitance? I only have a very basic DMM.
                                  For that cap, it usually lose its capacitance when it goes bad, so for now just verify the capacitance, SAMASUNG has common failure with the same type of cap in the same application of the circuit.
                                  • funtastic
                                    • Nov 2012
                                    • 63
                                    • New Zealand
                                    #37
                                    I removed C6111 from circuit and from what I read to put DMM on Ohms? It read nothing at all, tried volts as well and nothing came up.
                                    When I had C6111 in circuit and at 2000k it showed 270 Ohms and 0.02 Volts. With the switch activated it showed 384 Ohms.
                                    Tested R6120 and that showed 00.8 Ohms at 200 on DMM.
                                    Attached a picture to confirm I tested the right ones.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #38
                                      You need a esr meter really to test the esr and uf etc rating on capacitors as budm post 36 most bad caps lose its capacitance.
                                        You need to remove it and use capacitance meter to test the capacitance of that cap.
                                        • funtastic
                                          • Nov 2012
                                          • 63
                                          • New Zealand
                                          #40
                                          Thank you for the replies.
                                          I did ask if I needed an esr meter in the previous post but I felt it wasn't answered so I went ahead with the DMM.
                                          I'll buy one off ebay. Unfortunately it'll take a few weeks to receive. I'll post when I get it.
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • reporter1979
                                            2 red blink code on old led tv Sony KDL-40W2000
                                            by reporter1979
                                            Hi all, the TV KDL-40W2000 was flashed by a lightning.
                                            Firstly I got the 3 red blink code.
                                            Following other threads I changed the power supply board and got always 3 blinks.
                                            So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                                            The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                                            What else can I do?...
                                            02-17-2023, 11:50 AM
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • Storyteller12
                                            Sony XBR-65X900E 4 Blink Code
                                            by Storyteller12
                                            I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
                                            I don't work on Sony much but assumed it was backlights from what I read.
                                            Opened up the TV and tested all the backlights with led tester and the all work.
                                            I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
                                            So anyway to test these lights similar to the way we test...
                                            12-31-2022, 02:17 PM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
