Philips 40PFL7007K/12 does not power on - Chassis QFU1.1E LA
  • PeterH
    • Sep 2018
    Re: Philips 40PFL7007K/12 does not power on - Chassis QFU1.1E LA
    Hi Andronico and all,
    I'm fighting with a Philips 42PFL6678K, QFU1.2EE LA.
    The UART log looks very similar.
    0xF9892D1C cycle now
    Jump to 0xB5034100 02 key is used
    Getting Hash...
    0xBFC00000 01 10 00 00 52 55 00 0F 36 74 B3 80 00 00 00 00
    Hash:
    0xB5034570 1D 86 AE FF E3 71 65 8F 13 61 12 66 C4 5F 8D B0
    Buffer for BIG NUM is at B5034E2C, size is 0440.
    nand.c:nand_readwithinpage
    0x00000000 page is reading
    0x00000004 0x00000007 0x00000000 StartUnit/EndUnit/offset
    Reading out data:
    04 unit:
    waiting ECC result ready
    00 bits error in the unit.
    05 unit:
    06 unit:
    07 unit:
    0x00000001 page is reading
    0x00000000 0x00000003 0x00000000 StartUnit/EndUnit/offset
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    0x00000002 page is reading
    0x00000000 0x00000000 0x00000000 StartUnit/EndUnit/offset
    Reading out data:
    00 unit:
    {preboot}<break>
    <000><break>
    <010><break>
    <020><break>
    K<break>
    <break>
    Did you find a solution?
    I have the SPI EEPROM 7CT3 under suspicion but not sure.
    Is there anyone with an dump of this EEPROM for QFU1.2? Would be nice.
    br and thanks
    Peter
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4451
      • Italy - Milan
      At least you can try to read the SPI in the meantime you freeze it and if you obtain a dump that seems complete, watched with a hex editor then buy a replacement SPI and change/reprogram it.
      • Manniku TP
        • Feb 2014
        • Estonia
        Originally posted by nataf10
        Hi dear member,
        I read your topic about your problem with your Philips TV.
        I have the same problem with my own TV.
        I also measured the resistance across the 1V5 and it saw very low impedance 4.5Ω.
        Did you repaired your TV?
        Do you have any tips for me?
        I do likes the picture on this TV and I really want to keep it.
        Thank you very much for your help and time.
        Regards,
        Nataf10
        It is Processor failure.
        I had the same problem and the current consumption at 1.5 V was 5 amps. The power current was limited to 5 amps. The processor became very hot.
        • nataf10
          • Mar 2012
          • 37
          • Israel
          Hey,
          i did not success to repair the TV.
          I believe it was the main CPU.
          It is very hard to repair that kind of problem.
          wish you luck
          • dominik0801
            • Feb 2018
            • 98
            • Hungary
            I also had this problem not too long ago. Seems like the Fusion CPU gets killed by electromigration and heat.
            I bought my TV used in september, and it died on the 1st of december. I heated it. Also, I saw that it had already been heated by someone else before me, because there were flux near the CPU and stratches on the heatsink bottom.
            It worked for 2 weeks then died again.
            Heated it up again, and cut the back panel of the TV, to put a bigger heatsink with a fan on the CPU.
            It's been more than 1 month of it working. I hope it will last a while, I don't plan on buying a new TV anytime soon.
            • tuner2000i
              Philips 65PUS8518/12 distorted image after main board replacement
              by tuner2000i
              hello everyone,
              I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
              The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
              07-15-2025, 01:15 PM
            • cheeky2
              Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
              by cheeky2
              For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
              See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
              01-08-2024, 05:56 AM
            • HP32Sii
              Philips 50PUS6262/12 (chassis TMP17.7E LA) no picture
              by HP32Sii
              This is my first post on this forum, and my first attempted repair of a modern flat-screen LCD-TV (though I have repaired a few LCD-monitors, all with Elco-problems (high ESR). I have repaired my fair share of TV-sets and VCRs in the past ('90s) and was fairly familiar with the different Philips chassis (KT-3M, K12, K2, K3, K7 are some that come to mind). So I have a fair bit of experience on old sets. Obviously, modern TV sets are quite a different cup of tea.... no HOT or flyback-transformer inside, for starters....
              The set came into my possession by accident,...
              02-26-2023, 10:00 AM
            • charlesdutcher
              No picture issue in Philips Chassis FTL2.1
              by charlesdutcher
              My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
              Is there someone having any symptom like this? How to fix it?
              Thanks in advance!​
              08-06-2024, 09:55 PM
            • celiabrown
              Issue with Plasma Philips 37inch chassis FTL2.1
              by celiabrown
              Hello guys,
              My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
              Can someone has any symptom like this ?
              Thanks​
              05-09-2024, 10:56 PM
