I picked up a LG 60PY3DF everything works fine except the screen is dim and the images are shadows. See attached pictures. Any ideas what I can do to fix this?
LG 60PY3DF Screen Problem Pics Included
Tags: None
Re: LG 60PY3DF Screen Problem Pics Included
We need more detailed information. You didn't even say it was a plasma TV.
So, first start with standard plasma troubleshooting...
Check all your voltages including Vs, Va, Ve, -Vscan and report all that information here along with good pictures of the inside of the set so we can see the boards and how they are interconnected.Comment
Likely a Z-sustain issue (possibly IPM on Z-sus)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Okay I've got a update. I removed the back cover and did some prodding around. I powered the unit on and let play for about 30 min and felt the heat sinks on the Y-sus and buffers. They were nice and warm, so I checked the Z-sus board heat sinks and they were cool as a cucumber. I went ahead and checked the voltages going to the Z-sus and they matched the voltages on the spec label on the back of the screen. I saw Toms post and it confirmed what I thought might be the problem. I ordered a Z-sus and installed it last nite, hot dang that fixed it! I have to say it's one of the best TVs that I have rescued from the local landfill. Thanks Badcaps Forum!Attached Filesif you find these attachements useful please consider making a small donation to the site
I got it off fleabay for $48 shipped! Do you need a Z-sus, as I think the guy has one left.Comment
10-4 copy copy.Attached Filesif you find these attachements useful please consider making a small donation to the site
Watch multiple sporting events at the same time, and to showboat a little bit I reckon... Lol
Note: the 60" LG and 40" Samsung I picked up at the local landfill and fixed, the Samsung on the left a coworker gave me because lighting had hit it, and didn't want to pay $ to fix. Thanks to this forum and it's members, I've been able to fix 40+ TVs!Attached Filesif you find these attachements useful please consider making a small donation to the site
I have an LG plasma 60PY3DF also. It has the same shadow image if comes on for a second but it also clicks on and off constantly whenever plugged in could this also be the Zsus or do you think I have more than one problem?Comment
by mmccomputerI have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
If anyone has any information on the subject... -
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... -
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
