Vizio VX42L NO picture, good sound and LCD
  • charlesflynch
    • Jan 2015
    • 12
    • usa
    My vizio VX42LHDTV10A had the screen go blank.
    No previous flickering, etc.
    Yellow logo on standby, white when powered on.
    TV turns on/off normally and stays on or off.
    LCD is working, verified with a flashlight shining into the screen.
    Sound is working.
    Checked power supply board for bad caps, but all look good.
    with TV on, voltages from the power supply board are:
    24V is 24.2V
    5V stby is 5.17V
    12V is 11.69
    "A" is 2.89V (bl_on?)
    "B" is 5.02 (brightness?)
    PSON is 3.12
    Did a quick check of the LDOs on the main board, but all had the appropriate differential and/or fixed output.
    Looked at the Master/Slave inverter boards, and noticed the 4 large caps were bloated/blown, so i replace them with the same value, but 50v instead of 35v.
    Master Board:
    Philips LCD LC420WX7 6632L-0448A PNEL-T702A
    Slave Board:
    Philips LCD LC420WX7 6632L-0449A PNEL-T703A
    Unfortunately, that didnt help.
    Found 1 fuse on each inverter board and they were good.
    I tried jumpering the 5VSB to PSON before turning on tv to see if it was a timing issue, but no luck.
    I checked the 4 MOSFETS on the boards
    MQ1,MQ2,MQ4,MQ5
    1H46TA
    FDD
    8447L
    The top two (MQ1 and MQ4) have +24V on D, and 0 on both G and S
    The S of MQ1 feeds the D of MQ2, which has all pins at 0v.
    The S of MQ4 feeds the D of MQ5, which has all pins at 0v.
    The G of MQ1 and MQ4 are both traced back different pins on MU1, the main IC
    BS9897FS
    746 T49
    how likely is it that the main IC would go bad? It might be above my abilities to fix, but I might be able to get someone at work to help.
    Is there a way to make sure it's the inverter boards and not the actual CCFLs?
    I saw mentions of a mod for other phillips inverter boards, but not mine specifically, anyone know of a similar mod?
    Everywhere I looked on google, no one had the boards in stock. Anyone have any recommendations for a reputable store?
    Thanks for any help
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: Vizio VX42L NO picture, good sound and LCD
    Probably not the lamps unless they were (somehow) shorted to ground. If the lamps are old or one is bad, they usually flicker momentarily then the inverter senses an error and shuts down. Sounds like yours isn't even trying to come on.
    If the MOSFETs have 0v on their gates they are probably getting no drive signal from the controller ICs, unlikely both boards went bad at once, so probably the controller ICs aren't getting signal to turn on.
    Where do the inverter's control signals come from? Can you add photos showing what connects to what etc?
    -David VanHorn
      • 12145
      • U.S.
      I replaced some caps on philips inverter board, had to go back over my solder joints about 3 times to get it working, finely got it right, but I'm a pretty bad solderer.
        • 12145
        • U.S.
        on a lot of tvs, if I remember right, if the power supply has pull up resistors, try unplugging the ps-on plug from power supply or mainboard and see if backlights pop on, this might confirm inverters are good, someone please correct if thats wrong.
        • charlesflynch
          • Jan 2015
          • 12
          • usa
          I've tried looking at the IC's spec sheet, but couldn't find a good idea which one is the "on" line for the IC.
          for the inverter boards:
          There is an 11 pin ribbon cable connecting the master-slave inverter boards:
          1:SS
          2:VREF
          3UTY_OUT
          4:GND
          5:CT_SYNC
          6:GND
          7:SRT
          8:ON/OFF1
          9:ON/OFF2
          10:STB
          11:GND
          There is also a 4 pin ribbon cable going from the master to the TCON bd, but no clues as to what's on those pins.
          The master has a cable going to the pwr board with the +24, GND, ON/OFF, VBR-B
          The VBR-B is brightness, I'm assuming and ON/OFF is the BL_ON 2.9v
          The slave's to the pwr board only has the +24 and GND populated
          • charlesflynch
            • Jan 2015
            • 12
            • usa
            I'm not so good either, but one of the tech's at work called it "ugly but functional"
            I measured res between the cap's leads and the +/- power rails and got 0.00 ohms. Is there a better way to test?
              So let me get this correctly, you did not see the backlights flash on at all? and the fuses are OK on the inverter board?
              "I measured res between the cap's leads and the +/- power rails and got 0.00 ohms." I do not understand the readings, do you mean the resistance between the two legs (+, -) shows 0 Ohms?
              The IC on the Inverter looks OK?
              • charlesflynch
                • Jan 2015
                • 12
                • usa
                Originally posted by charlesflynch
                8:ON/OFF1
                9:ON/OFF2
                10:STB
                Ok, looked a bit closer and it seems as though on the master bd the On/Off from the pwr supply board goes to ON/OFF2 on the mas/slav ribbon. On the slave these two are connected together, so ON/OFF1 on the master will have the ~3v when the slave is connected. ON/OFF1 goes through a 10k resistor an then to pin16 on the IC (labelled as STB) which is also pin 10 on the mas/slv ribbon.
                Just checked and on both the master and slave, ON/OFF1 and ON/OFF2 are both at 2.88v and STB is at 0.7V
                looks like i need to figure out what else is on the STB line
                • charlesflynch
                  • Jan 2015
                  • 12
                  • usa
                  no flash or any signs of life from the backlights.
                  found 1 fuse on each inverter, both boards measured to be good.
                  + lead of each cap to +24V is 0.0 ohms
                  + lead of each cap to the other + cap lead is 0.0 ohms
                  - lead of each cap to GND is 0.0 ohms
                  - lead of each cap to the other - cap lead is 0.0 ohms.
                  We have capacatince meters at work, so if I get time, I'll try to measure the boards tomorrow. obviously will have the 2 big caps in parallel as well as other board stuff, but should give a rough idea of if i'm close?
                    The caps are connected in parallel, the minus is connected to the circuit ground (24V return), the Plus are connected to the fuse which is fed by the 24VDC B+.
                    The master-slave inverter are setup as push pull to drive the lamps, The master inverter send the drive signal to the slave to synchronize the circuit of the master and the slave. If the Master inverter board is working but the slave is bad, you will see one side of the screen lights up only, if the Master is bad but the sync signal is still good, the you will see the other half of screen lights up only.
                    So right now the MASTER is not active.
                    There is a small flat white cable between the Master inverter and the T-CON board, remove it to see if you will get the backlights, this TV has what is called Dynamic Contrast function so they can claim that the TV has high contrast ratio (B.S), the brightness of the backlights is controlled by the T-CON which depends on the scene of the Videos.
                    • charlesflynch
                      • Jan 2015
                      • 12
                      • usa
                      Took your suggestion and disconnected the ribbon from MAS to TCON, but still nothing on the tubes at all. I even turned the light out in the garage to see if there was something faint, but no luck.
                      I found 1 fuse on the TCON and it was good.
                      Found 1 LDO and is seems good.
                      RT9164A
                      15CG9L OK
                      1:0v
                      2:1.5v
                      3:3.3v
                      There is an LED MD1 on the master only, that lights up bright when you power on the TV, but fades off within 1-2 seconds. Unfortunately I dont know if that's normal operation or not.
                        "There is an LED MD1 on the master only, that lights up bright when you power on the TV, but fades off within 1-2 seconds." That is correct.
                        I expect the lamps to flash on then what ever is wrong with the circuits is then detected and goes into shutdown, so we must be missing something here.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4951
                          • New Zealand
                          Something dead in the inverter that didn't blow the fuse? The inverter controller tries to start, and shuts down? The backlights never flicker because whatever is bad stops them from getting any power?
                          -David VanHorn
                            He can try replacing the IC that will be my first choice.
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • ggil44
                              Vizio M65-E0 No Picture, No Sound
                              by ggil44
                              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                              09-03-2024, 08:30 PM
                            • totof
                              EU55JS9000T black screen and sound good
                              by totof
                              Hello.
                              I have this issue on my Samsung EU55JS9000T TV.
                              Backlight is good when the one connect box in not connected to the TV and I can launch the TCON screen test with the remote control.
                              But when I connect the one connect box the backlight immediatly turn off, the sound is OK (TNT source).
                              I dont know if the problem is from the one connect box or from the internal motherboard of the TV.
                              I open the one connect box (reference BN96-37087R) and all seems good, simply the Hawk-P CI is very hot after 5 minutes (~65 degres).
                              Is someone have experience...
                              09-25-2023, 03:23 PM
                            • totof
                              LG 43UF640V backlight good but black screen and no sound
                              by totof
                              Good morning.
                              I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                              I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                              In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                              HVDD : 7,28...
                              04-13-2024, 11:37 PM
