problem with Sony KDL-40EX403
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys i got a Sony KDL-40EX403 TV that has a fault.
    when you power on TV you get red led on front and when i press the power button the LED goes green, not wierd i know but tv doesnt have any backlight and doesnt display a picture as i shined a bright light on it to see if i was getting any display to which i was not, pressing menu and volume etc made no image on screen.. i tried googling the model number to see if anyone had any similar faults but had no luck at all..
    anyone else had an issue with this TV or had another tv with same problem ?
  • nomoresonys
    • 12206
    • U.S.
    Re: problem with Sony KDL-40EX403
    did you try a firmware update?, thats if you can find one on sonys inadequate web site.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      would it still take an update though even if theres no display ?
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        step 3 after putting in USB is to follow on screen instructions but i wont see them ?
        • nomoresonys
          • 12206
          • U.S.
          ok, my kdl-46s4100, updated when I powered set up, I just had steady green light, yours may be different.
          • nomoresonys
            • 12206
            • U.S.
            unless there is nothing to do, just watch screen, not sure.
            • nomoresonys
              • 12206
              • U.S.
              has anyone else updated this model?
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                tried just plugging in USB with the update file, steady green light but no picture or backlight.. im just wondering why there is no display or no backlight could it be a mainboard issue ?
                • nomoresonys
                  • 12206
                  • U.S.
                  try unplugging the bl-on plug from the main or power supply and see if the backlights pop on.
                  • nomoresonys
                    • 12206
                    • U.S.
                    the way my model update worked, is tv off, plug in usb drive, power on, light green goes double amber for about 2 minutes, when it stops blinking turn off tv, take out usb.
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      turned tv off plugged in USB and switched TV on and just green light nothing happened
                      • nomoresonys
                        • 12206
                        • U.S.
                        wrong post
                        • nomoresonys
                          • 12206
                          • U.S.
                          http://www.toms-service-manuals.com check there, put in sony and your model number, I'd check the training manual it's an 80% match.
                          • nomoresonys
                            • 12206
                            • U.S.
                            did you try my suggestion in post#9?
                            • nomoresonys
                              • 12206
                              • U.S.
                              manual says check your 3.3v and 12v, on power supply, see if they are correct.
                              • danielnaidoo2014
                                • Jan 2014
                                • south africa
                                Hi i have a sony lcd tv model kdl46ex500 need some help
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Hello for this issue you are having you should really start a new thread and tell what your symptoms are. Does it power on? Any backlights?
                                  Originally posted by danielnaidoo2014
                                  Hi i have a sony
                                  • Mikeyboy2007
                                    • Mar 2013
                                    • 745
                                    • Scotland
                                    ok I know this thread is a little out of date but I received another one of these with the same issue and would like to resolve it this time around. I cut the wire for BL_ON and switched tv on, made no difference.
                                      Can we see the pictures of the whole backside of the TV so we can see all the boards?
                                      • Chrissygizmo
                                        Sony KD-55XG9505 lines on screen problem
                                        by Chrissygizmo
                                        Hello again everyone,
                                        This is my latest mission, to try getting this Sony tv back to normal working order…
                                        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                        02-19-2025, 11:31 AM
                                      • crackedprint
                                        Sony HCD-HX80R Amplifier Volume Control Problem
                                        by crackedprint
                                        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                        I have tried a Cold Reset as per the service manual.
                                        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                        I have looked all the way through the service manual and tried many online...
                                        01-21-2025, 12:18 PM
                                      • retrorepair
                                        SONY KDL-40P3600 Picture Problem
                                        by retrorepair
                                        Hello gurus, hope you can assist me...
                                        I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                                        I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                                        Thanks in advance.
                                        10-11-2024, 05:12 PM
                                      • guruji
                                        Sony mbx-266 problem
                                        by guruji
                                        Hello
                                        I this Sony mbx-266 it powers
                                        on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
                                        07-25-2025, 08:10 AM
                                      • YasaCh
                                        sony kd-49xf9005 4 red blinking problem
                                        by YasaCh
                                        Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                        05-05-2025, 08:40 AM
