sansui sled3200b no image or backlight
+ More Options
Posts
  • maiden790
    • Nov 2014
    • 94
    hey guys im having this weird problem with this sansui 32 inch
    It powers on and off fine but there no back lights or image that i can see with a flashlight.. none of the capacitors are blown and the fuses seem to be good as well. anyone have this experience with any other tv before? here are some pics ( excuse the mess )
    one mans is another ones treasure
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: sansui sled3200b no image or backlight
    Do you mean the TV is not powering up or it is turning on and you have audio but no backlight and picture?
    • maiden790
      • Nov 2014
      • 94
      its turning on just no picture or back light
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        OK then you may have a Main Board issue...
        • maiden790
          • Nov 2014
          • 94
          okay thanks
          • selldoor
            Slow Learner
            • 7870
            You may also have a problem with the Led driver board in pic 1 or with the led strings.
            What voltages do you get on the led board?
            Try unplug the led board and see if you see the picture using the flashlight.
            If you do then try reconnecting the led board but unplug the ribbon cables and see of you still see a picture. ( Trying to establish if problem is the board or the strings)
            • maiden790
              • Nov 2014
              • 94
              well heres my problem, im getting voltage to the board however i dont know what voltage i should be getting! nothing is labeled on either parts, usually it'll have it labeled next to each pin but this isnt the case. am i missing something??
                Can you upload the pictures of the whole back side of the TV so we can see how all the boards are connected together?
                • maiden790
                  • Nov 2014
                  • 94
                  heres the back side
                    Back side of the TV so we can see all the boards.
                    • maiden790
                      • Nov 2014
                      • 94
                      oh sorry!
                        Just a quick check, the LED driver board on the bottom right of the picture, please check the DC Voltage on two legs of that black filter cap laying on it side. Tell me what it has on it, also tell me the rating as printed on the body.
                        • maiden790
                          • Nov 2014
                          • 94
                          the cap says 63v im getting a reading of 0.40 if im even doing it right . ( keep in mind im new to this )
                            OK, the booster circuit is not on.
                            On the power supply board, you said you are getting Voltages, can you tell me the Voltage of each pin of that white connector that goes to the LED driver board?
                            • maiden790
                              • Nov 2014
                              • 94
                              1st- 2.24
                              2nd- 2.86
                              3rd- 0
                              4th- 0
                              5th- 0
                              6th- 1.43
                              7th- 1.43
                              8th RED - 1.43
                              • Salem Aboshala
                                820-00138-A got image but no backlight
                                by Salem Aboshala
                                Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                                I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                                History: my laptop backlight stopped working without any reason.
                                Symptoms:
                                I have image on screen using my flashlight.
                                I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                                Keyboard backlight still working and can be adjusted normally.
                                Since two days I tried to follow all similar...
                                06-11-2024, 03:02 PM
                              • zaurus81
                                Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                                by zaurus81
                                This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                                The board is equipped...
                                01-16-2025, 03:54 AM
                              • Constantinos
                                Macbook Pro A2442 820-02098 No image but has backlight
                                by Constantinos
                                Hi all
                                I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                08-24-2024, 09:48 AM
                              • ajgae
                                HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                                by ajgae
                                Hi everyone!
                                First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                                03-06-2025, 09:53 AM
                              • learnmore
                                Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                by learnmore
                                Hello Community!
                                CASE DETAILS
                                Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                Tried inserting firmware on USB and left it in for a few hours, but no change
                                03-03-2024, 09:49 AM
