RLDED3258A-F another crap TV from RCA
  • paulstef
    • Dec 2013
    • 724
    Re: RLDED3258A-F another crap TV from RCA
    I ended up lowering the LED current to 117mA without seeing much difference, perfectly ok for me.
    This decreased the stabilized core temperature to about 40C increase over ambient temperature. So in my 10C basement that means 47C.
    Now the only thing left to do is to figure out how much money I can charge for spending 20h repairing a TV that costs new $200CAD. Well I guess sometimes it's not for the money. :-)
    • bakesbrownies
      • Feb 2015
      paulstef
      I have the same board and problem. Looking to replace l1 inductor with a new part. Would a 47uH 6A part be acceptable?
      • paulstef
        • Dec 2013
        • 724
        Originally posted by bakesbrownies
        paulstef
        The inductance looks about ok. 6A is well above what I measured .
        • tommyg
          • Apr 2015
          Well I'm glad I found this thread, I just wish I found it sooner. Now I don't feel like a moron for spending several hours trying to fix this shitty tv to no avail
          • magictech
            • Sep 2016
            • 3
            Hello all. I'm new to this forum as a member but have been into electronics since the days of vacuum tubes and this thread is exactly on the subject I've been looking into. I picked up for a buck an RCA RLDED3258A with hopes to be able to put it in our small travel trailer. I was told " it has sound but no picture " and I've seen this before in these P.O.C. units and ,sure enough, it had one burned out LED back light. After tracking down and installing a replacement LED, I checked for any defective parts and all looked good. I fired it up and, after the normal wait , I got a bright flash from the LEDs but then nothing. I figured from this that the LEDs were good as well as the FET and L1 as it would repeat this every time I fired it up. I would like some advice as to where to go from here. Any ideas? Thanks. Bob
              You need to check the Voltage feeding the Anode of the LED string to see what it is when it flashes and when it goes black, and are you sure that there were no shorted out LEDs beside the one that burnt up and goes open circuit?
              Did you verify that all the LEDs come on when you had the LCD panel apart after install the new LED?
              • magictech
                • Sep 2016
                • 3
                It's after midnight here now but I'll do the check in the a.m. Yes, all LEDs flashed and I was able to test each LED with my meter on diode check. Each one glowed at equal brightness: no shorts or opens.
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                  Corsair CX750M [Model 75-002019] - burned output toroid inductor
                  by momaka
                  Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                  So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                  09-19-2021, 08:44 PM
                • Nooy
                  VGA MOSfet permanently shorted and loss of MOSfet pad
                  by Nooy
                  Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                  I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                  02-14-2024, 02:26 AM
                • Reintar
                  Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
                  by Reintar
                  First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
                  One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
                  08-30-2024, 06:13 AM
                • redbaron1007
                  Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                  by redbaron1007
                  I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                  Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                  09-09-2025, 11:10 AM
