LG 42LG30 - Another backlight question, but I've read the others :)
  • DLinkOZ
    • May 2013
    • 238
    Grabbed this as a cheap TV for the game room. My symptoms are very similar to this thread:
    https://www.badcaps.net/forum/showthread.php?t=20203
    I have the same transformer readings, and my fets all seem good. Additionally, if I unplug the output cable from either inverter (disconnect from the ccfls) the TV will power on and stay on, but with no backlight (obviously). If I leave them connected, it power cycles.
    It *seems* as though the inverters are good, and I need to inspect the ccfls themselves. Is there a service manual or nugget of wisdom for the easiest path to them? Normally a full tear down would be easy enough, however the TV needs to power on with the lamps exposed to give a proper visual.
    Input is greatly appreciated!
    • 12276
    • U.S.
    Re: LG 42LG30 - Another backlight question, but I've read the others
    not sure, maybe a fault coming from inverter/s is causing it to go into protection mode.
    • DLinkOZ
      • May 2013
      • 238
      I was originally expecting that, but I can unplug either the master or the slave from the ccfl plug and get it stay on. I may be misreading the result, that to me points towards the bulbs.
      **EDIT**
      To clarify, when I unplug the output to the bulbs I leave both inverters connected and powered on. And I only have to unplug *one* of the outputs - either the master or the slave, either one alone will allow it to stay on.
      • DLinkOZ
        • May 2013
        • 238
        I got a quick peek under the panel, and I can't see any dark spots. The bulbs look good. so it may be as simple as a set of inverters (for the price, I might as well grab both).
          • 12276
          • U.S.
          well if you get some in working order, at least that should rule them out as the problem, please keep us updated.
          • DLinkOZ
            • May 2013
            • 238
            Replacement inverters did the trick. This is going with another 42" I have in my game room. Opposite corners connected to an xbox 360 kiosk. My game room is also my arcade
              Thanks for the follow-up.
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • DanPoka
                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                by DanPoka
                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • cheebster
                iPad Pro 12.9 5th Gen Backlight Issue
                by cheebster
                Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                Anyone...
                05-20-2025, 09:17 AM
              • canadaboy25
                LG Flatron 24EN33TA No Backlight When Cold
                by canadaboy25
                I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                03-07-2023, 12:23 AM
