sourcing led backlight strips...
  • lookimback
    • Aug 2013
    • 1489
    Re: sourcing led backlight strips...
    Possibly. Just hard to tell from a pic.
    ------------signature starts here------------
    • Ltank
      • Jun 2013
      • 776
      I found on some LED strips like you showed usually 4 chnnels each channel had 25 leds.
      They are a pain to remove becsause the back of the LED where its bonded to heatsink with a heatsink epoxy. without it they get too hot and fail prematurely.
      • hicksvilleshick
        • Oct 2014
        • 42
        • United states
        Where did you find these??? Sounds right cause these are like super stupid sticky glued to the metal...
        :chug:
        • lookimback
          • Aug 2013
          • 1489
          These ones have a ground plain on the back. Real pain to get off in one piece. I got about 10 off, but at the expense of ruining the strip. I sliced them off with a sharp razor and then removes the remains of the traces from them. I think you are going to have to just get them hot and break them in half, if you don't want to damage your strip. And these work at 3.2v, I'm blind now BTW.
          • hicksvilleshick
            • Oct 2014
            • 42
            • United states
            LOL! I'm sorry your blind now. I guess I'm not following how your talking about putting them back on... Would getting them hot and breaking them in half, um, break them?
            • lookimback
              • Aug 2013
              • 1489
              I mean, removing the bad ones from your board. I'm saying, trying to remove them in one piece will probably result in damaging the rest of your strip, which you need to save. If you just get them hot enough, they will break apart. Then you can desolder the individual pieces from the strip. I already got 10 off and they are in good shape.
              • hicksvilleshick
                • Oct 2014
                • 42
                • United states
                #27
                oh. We've already removed what we believed was the bad one... with a pocket knife... :yikes:
                :chug:
                • lookimback
                  • Aug 2013
                  • 1489
                  Oh, OK. I just did the same with a razor and flooding it with solder. Melting didn't work so good.
                  • lookimback
                    • Aug 2013
                    • 1489
                    I would test the rest of them. Use 2 AA batteries in series. 2 new ones will be about 3.2v. The end with the little dot is positive. Wear sunglasses.
                    • lookimback
                      • Aug 2013
                      • 1489
                      Putting them on is going to be tricky. You have to be quick, or they melt. Once you get them in place, you have to somehow heat the bottom to reflow the solder on that ground plain, or they won't last long.
                      • hicksvilleshick
                        • Oct 2014
                        • 42
                        • United states
                        #31
                        Duuuude. Thank you so much, I'm just happy to have a direction to go...
                        sucks to have that nice tv and 1 stupid little part keeps it from working...
                        :chug:
                        • lookimback
                          • Aug 2013
                          • 1489
                          It's nothing. I'll get them in the mail on Monday. Just be certain to let us know how it goes. And pay it forward.
                          • lookimback
                            • Aug 2013
                            • 1489
                            I think I'm going to see if I can use one of these for a bulb in my mini Mag lite. These things are super bright.
                            • DanPoka
                              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                              by DanPoka
                              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                              02-15-2025, 05:05 AM
                            • Comp_Pro
                              No Backlight Macbook A1990 820-01041
                              by Comp_Pro
                              Hello all,
                              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                              Tests performed:
                              There is no backlight even with a good screen.
                              Backlight IC is receiving the correct support voltages.
                              Fuse F8400 ok
                              Current sense resistor R8400 ok
                              Backlight IC is receiving 3.3V on enable pin.
                              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                              Backlight IC receiving 5V from PP5V_G3S
                              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                              05-06-2024, 10:23 PM
                            • DXseekerMO
                              Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                              by DXseekerMO
                              Hello everyone!
                              Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                              I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                              Yes
                              0%
                              1
                              All backlight strips are the same quality
                              0%
                              1
                              No
                              0%
                              0
                              12-16-2021, 03:58 PM
                            • cheebster
                              iPad Pro 12.9 5th Gen Backlight Issue
                              by cheebster
                              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                              Anyone...
                              05-20-2025, 09:17 AM
