3 tvs 3 different issues 1 thread
  • christo
    • Jan 2015
    • 25
    • canada
    I've been lurking for the passed two weeks and have now registered to try and get some assistance so I can get some sleep!
    Problem tv # 1: 32 inch samsung lcd
    The samsung tv has no picture just a 1 inch strip at the bottom of the screen, everything else is white horizontal lines with black background.
    It has sound and turns on easily.
    I've reseated all cables and ribbons with no luck.
    After multiple tests I've decided must be a bad panel but I decided to ask everyone else's opinion.
    Problem tv # 2 RCA led flat screen
    Only turns on after multiple tries of unplugging and plugging in.
    I've switched a few caps and a cold soldering joint to no luck the issue remains, I will be switching all caps on psu to see if this works tomorr only tried a few so far.
    If I turn the tv off I have to redo the unplugging process to get it to power on.
    Problem tv 3 : Philips 40 inch lcd turns on, back light is in on, no picture or sound, I replaced two caps that kinda looked funny and to no avail that didn't work so I reseated the cables and It did nothing. There is a clicking noise when plugged in. Also has no standby light just a white power light whenthe tv turns on
    Models and pics of all board will be posted tomorrow, I decided to post thread tonight to get a head a little.
  • nomoresonys
    • 12331
    • U.S.
    Re: 3 tvs 3 different issues 1 thread
    read the stickie posts, try to post some good clear pics., of all the individual boards and pics. of how they are all connected, a pic. is worth a thousand words, it might get pretty confusing only having one thread for 3 tvs.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      I agree - it will be horrendous 3 separate threads required.
      I was going to try and justify that but I dont think there is any need.
      Header for each thread should include make model no and brief description
      of problem. In each thread if you are changing or have changed caps tell us what you used- for a power supply they should be low esr known good make from a known good source
      • ScHAmPi
        Samsung UE48JU7000 screen issue after backlight replacement
        by ScHAmPi
        Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
        I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
        07-15-2024, 05:41 AM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • gretti
        MSI Z370-A Pro, works but does not power off or reboot and USB issues
        by gretti
        I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
        The MSI BIOS included the ME firmware for the board. The size...
        10-16-2025, 02:14 AM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
