ps50a457 turns on screen is lit but no picture
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all I need a lil help before buying a replacement power board
    I have this model tv in and the picture wont display but the screen is lit up dimly
    I have tested vs and va from the main test pin and have proper voltages 56v for va and 207 for vs now from the va connections to y and x are low 15v and vs is fine 207v
    so from the va test pin to the main x or y connection on the power board with out x and y main connected or connected I lose voltage
    picture to show whats what
    any ideas please
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: ps50a457 turns on screen is lit but no picture
    Tried leaving tv on for 30 mins. No change
      Check Va fuse on plasma X-boards (E/F-buffer) (runs along bottom of panel)
      • wreksta
        • Aug 2013
        • 508
        • england
        Spot on tom mate but before I replace the fuse
        What would have caused it to blow
        I did change 2x 100uf 50v caps on ymain
          Can blow without cause or can be bad plasma panel or bad E/F buffer shorted.
          • sordids999
            • May 2013
            • 2158
            Any ideas the text on the screen is from a dvd player
            VS 200
            VA 56
            VSCAN 186
            VE 99
            • Hamie
              • Apr 2014
              • 1383
              Z-sus by the looks of it.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Xsus little green fuse fails normally due to bad cap Samwha Pt 680uf 25v.
                • sordids999
                  • May 2013
                  • 2158
                  yes correct m8 forgot to add bulged cap on the YSUS,PSU and the 25v 680uf on the Xsus all changed
                  checking the fuse
                  thanks
                  • sordids999
                    • May 2013
                    • 2158
                    UPDATE:
                    fuse changed tv all working again
                    thanks
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • frannyjunk
                      Hisense 40H4F no backlight but turns off after splash screen
                      by frannyjunk
                      So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                      TIA.
                      09-24-2025, 10:59 AM
                    • mrtek
                      Vizio M65-C1
                      by mrtek
                      Hi.
                      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                      07-14-2025, 07:28 PM
                    • arbitarytwist
                      Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                      by arbitarytwist
                      Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                      Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                      03-01-2025, 01:16 PM
