INSIGNIA NS-L47Q09-10A: No Sound, No Picture
  • magicjeep
    • Apr 2015
    • 11
    Re: INSIGNIA NS-L47Q09-10A: No Sound, No Picture
    Originally posted by budm
    That black fuse is the common failure, I have fixed so many of these CMO boards and they are just bad fuse, I used PICO II fuse (you have to bend the legs to install it) and none of the repairs come back.
    You can jump it for testing (or use 1~4.7 Ohm 1/4W resistor), the circuit draws <0.5A.
    Would this be a replacement for the fuse?
    http://www.radioshack.com/4-7k-ohm-1...l#.VTgOEv7F_dp
    If not could you direct me to the correct place. Thanks
      That is 4700 Ohms not 4.7 Ohms.
      http://www.radioshack.com/74-mf1a-b-...2Bfuse&start=4
      http://www.digikey.com/product-detai...2313-ND/700718
      • magicjeep
        • Apr 2015
        • 11
        Duh, I didn't see the k after the 4.7. So 1 of those would replace the flat square black fuse? I apologize for my newb questions but I really don't want to buy another tv and I want my kids game systems back in the basement. lol. Again thank you very much
          "So 1 of those would replace the flat square black fuse?" yes, no need to remove the old fuse either, just have good soldering skill and good iron and flux.
          • magicjeep
            • Apr 2015
            • 11
            Thanks for the help. I'm going to run over to radio shack tomorrow, if it's still open, and see if I can pick them up. Also you're not kidding about good soldering skills those things are tiny in a tinier space.
            And another duh, it's online only. I really should learn how to read.
            • newtothis
              • Mar 2013
              • 1556
              • england
              #26
              Flux is key
              • magicjeep
                • Apr 2015
                • 11
                What would the small white fuses be?
                http://www.newark.com/littelfuse/045...E?gross_price=
                  Did you check the white fuses with TV plugged in? should not be plugged in.
                  Also sometime there are flux built-up on the solder ends of the SMD component so you may have to clean the flux off first to get good readings.
                  If the white fuses are blown then you have bigger problem, please verify for sure that the white fuses are good.
                  • magicjeep
                    • Apr 2015
                    • 11
                    Ok here's an update. First thank you guys for the help so far. I purchased a new board and installed it today. Now when I press the power button I get a flash of "PLEAS WAIT" on the screen. After the please wait, the screen goes black and I get nothing. No sound no picture, nothing. I had 2 devices, a wiiU & directv box, plugged into the HDMI ports. I tried changing the input using the side buttons and still nothing. What should be my next step?
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #30
                      Do you have sound?
                      • magicjeep
                        • Apr 2015
                        • 11
                        Nope. I tried turning the volume up with the buttons and I got nothing. I also tried shining a light in the screen and I couldn't see anything. The only thing with the sound is I'm not sure if the devices that were plugged in were making noise. I'm going to find a dvd player and throw it on the tv.
                        • shumiron
                          • Jun 2015
                          • 26
                          Please help - Insignia NS-L37Q-10A. Same symptoms except i did detect sound at one time. Turns on - 'Please Wait' - then black screen altho in the dark I can see some light at top center. no other indication that the screen is alive. I am having trouble removing back, tho. Seems like there is something attached around the I/O connectors. Do I need to remove the VGA posts?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5095
                            • New Zealand
                            #33
                            The little hex screw\nuts? They usually do attach to the case on things for physical support when you plug the cable it.
                            -David VanHorn
                            • shumiron
                              • Jun 2015
                              • 26
                              I got the back cover off. i checked voltages on power board and only have 5 V on the two 5 V pins. All other pins show nothing. Any ideas on what may be wrong with the power board?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5095
                                • New Zealand
                                #35
                                If all you get is the 5v standby rail, it sounds like the mainboard is not sending PS_ON signal to tell the PSU to come out of standby.
                                To check if the PSU is OK, try disconnecting the PSU from the mainboard, then jumping PS_ON to +5v standby rail via a 1K resistor and see if the PSU turns on. Check the voltages again and see if they are OK.
                                -David VanHorn
                                • shumiron
                                  • Jun 2015
                                  • 26
                                  OK. I will report back later today. Thanks for the info. One item of interest, tho, is that when I turn TV on the 'Please Wait' graphic appears for a few seconds then the unit is dead, altho i did hear some sound when I hooked up to XBox with HDMI.
                                  • shumiron
                                    • Jun 2015
                                    • 26
                                    I jumpered 5 V to the PS_ON and all the voltages on the power connector are correct. What next? Main Board problem?
                                      The main board did send the PS-ON, BL-ON otherwise you will not have backlights and sound. So verify that when it goes black after few seconds the PS-ON and BL-ON are still present. If there is no backlights but the sound still keeps on working then the PS-ON did not go away.
                                      • shumiron
                                        • Jun 2015
                                        • 26
                                        Thanks, Bud. I have gone to your site with all the helpful pictures and info....plus the bootiful kitty. I need to check again tonite if the back light is completely on. I checked a couple nights ago and it seemed the light was on in a small area of the screen near the top center. I checked the power supply connector without connection to main board. I can't seem to get the meter probes to get far enuff in to the connector to contact the metal. So when I was checking voltages before the PS_ON signal wasn't getting back to the power board since I had the connector off. I will do some more testing with all connectors attached.
                                          This model has many different versions, so which are your boards:
                                          http://www.shopjimmy.com/catalogsear...+NS-L47Q09-10A
                                          • jose6326
                                            Insignia Ns-l22x-10a no picture only sound
                                            by jose6326
                                            When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                                            When i was removing the back cover i heard a rattle.
                                            Removed the metal plate and the heat sink was off (see pic)
                                            would this cause a no picture/image issue?
                                            What is used to put back the heat sink
                                            07-30-2024, 11:03 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
