Insignia Ns-l22x-10a no picture only sound
  • jose6326
    • May 2013
    • 707
    When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
    When i was removing the back cover i heard a rattle.
    Removed the metal plate and the heat sink was off (see pic)
    would this cause a no picture/image issue?
    What is used to put back the heat sink
ID:	3319523 Click image for larger version
ID:	3319525 Click image for larger version
ID:	3319526 Click image for larger version
  • ipyongtech
    • Nov 2020
    • Philippines
    Maybe backlight problem. You can confirm it using flashlight point it to tv screen while tv is power on and check if you can see some display. If have display then you have a problem with your backlight or inverter.
    • jose6326
      • May 2013
      • 707
      how to a attach the heat sink back to the chip?
      • lotas
        • Jan 2016
        • 4901
        • Russia
        For this purpose, there is Hot-melt adhesive STARS-922 HEATSINK PLASTER.
        https://aliexpress.com/item/1005004000596248.html
        • nomoresonys
          • 12332
          • U.S.
          You might want to hold up on putting the heatsink back on til after testing, it's ok to test without heatsink on as long as tv is not on for too long.
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
