Samsung LA32B350F no backlight
  • vinceroger69
    • Mar 2012
    • 6714
    #61
    Re: Samsung LA32B350F no backlight
    im on 230v ac myself your voltage readings dont make sence too me with tv pfc psu s i get roughly 325v in standby and roughly 390v when the sets running
    • mrobo
      • Nov 2006
      • 36
      • Bratislava
      #62
      you got right guys it is conversely i made mistake with the red power led on tv
      it is so: when the tv is in standby the red led lights on
      when I power on the tv the red led 5x times blink and stays off
      sorry my mistake
      • mrobo
        • Nov 2006
        • 36
        • Bratislava
        #63
        ok new measuremets (my input is 227V AC I am from EU):
        in stand by:
        CP815 = 304V
        1. Power On/Off = 0,01V
        2.7.5. = 5,15V
        4.10.11. = 13.04V
        12. InverterOn/Off = 0V
        13. E-PWM = 0V
        14. DET_5V = 0,01V
        in powered on:
        CP815 = 300V
        1. Power On/Off = 0,76V
        2.7.8. = 5,14V
        4.10.11. = 13.01V
        12. InverterOn/Off = 5.1V
        13. E-PWM = 2.02V
        14. DET_5V = 0,12V
        • vinceroger69
          • Mar 2012
          • 6714
          #64
          cp815 is that the maximum voltage it gets too as i just tested a working psu and i get roughly 390v when psu is on
            So now you longer get the 396VDC boosted Voltage? Without that the rest of the power supply and the circuits that require the boosted Voltage will not function.
            • vinceroger69
              • Mar 2012
              • 6714
              #66
              I dont see how his voltage readings listed below keep altering all the time
              one minute the pfc voltage is good one minute its not
              in stand by:
              CP815 = 304V
              2.7.5. = 5,15V
              4.10.11. = 13.04V
              13. E-PWM = 0V
              14. DET_5V = 0,01V
              in powered on:
              CP815 = 300V
              2.7.8. = 5,14V
              4.10.11. = 13.01V
              13. E-PWM = 2.02V
              14. DET_5V = 0,12V
                I know, I mention that about the DCV on the main cap to be that low in standby when the AC Input is at 327VAC and the cap Voltage is only 304VDC. It is either measurement error or the meter, etc.
                I.E.:
                2.7.5. = 5,15V
                4.10.11. = 13.04V
                It is hard to troubleshoot the problem with bad data.
                The format of the report is also confusing.
                Pin 2 is 5.15V pin = 7.5V?
                Pin 4 is 13V pin = 10.11V?
                Not the same format as used in post 39.
                Hard for me to do any more helping at this point.
                Need to get that Voltage on the main cap correct first by checking that main filter cap, solder joints, bridge rectifier, etc..
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #68
                  I know im still learning myself but it does test your patience at times with bad data readings etc, its like when we have too ask more than once in diffrent threads for pictures etc of there boards we dont always have time too look on shopjimmy and upload them ourselves etc, also we dont always know the board/revision part number i think its stopping a lot of experienced members on here offering advice in my opion.
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    #69
                    this may be not be possible, but i was just wondering if there could be a template used to start a new thread. that way all the info to start off would be available from the beginning, outside of updated pictures and the like, but it could make things flow a little bit smoother.
                    just a thought.
                    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      #70
                      Well I just made a text file so I can just copy and paste. Gets real tiresome asking for same info all the time.
                      • mrobo
                        • Nov 2006
                        • 36
                        • Bratislava
                        #71
                        I.E.:
                        2.7.5. = 5,15V
                        4.10.11. = 13.04V
                        It was meant so:
                        pin2. pin7. pin5. = 5,15V
                        pin4. pin10. pin11. = 13.04V
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #72
                          As budm says your next step now is you need to get that Voltage on the main cap correct first by checking that main filter cap, solder joints, bridge rectifier, etc and get it as close to 390v as you can when the set is powered on.
                            Originally posted by mrobo
                            It was meant so:
                            OK, that clears up the readings.
                            • mrobo
                              • Nov 2006
                              • 36
                              • Bratislava
                              #74
                              Today I made measurements with other digital multimeter tool, with Metex M-3650D (putted new battery into)
                              I uploaded it in excel, I hope it is clearly now.
                              I measured all diodes in circuit with nothing bad found, some of them out of the circuit and measured with no problem found, like the
                              ZM801 .989 PN, 141 KOhm PN
                              in power circuit:
                              ZM804 .973 PN 135 KOhm PN
                              ZD804 .965 PN 135 KOhm PN
                              ZD803 .965 PN 131 KOhm PN
                              of course in NP all have open circuit
                              visually inspected the electro caps no problem found, measured in ohm if they charge and discharge in circuit and no problem found
                              some of them I changed even they seemed to be good (found recomendation in this badcaps forum with similar problem )
                              DP805 I have with number 31GF0927G should I change it?
                              Because Samsung SEUK Technical Support Service SVC Guide for No Power to Backlight caused by diode on IP Board.
                              I measured it and for me seems ok.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #75
                                you are getting some voltages im not 100% there all correct though and the maximum the pfc goes to is 308v with tv on that does seem low maybe budm has some ideas what to check/advise next
                                  So the DCV between the two legs of the main filter is lower than normal with 225VAC input so the bridge rectifier, connections, etc should be checked. You also do not have boosted Voltage when PS-ON is present. The 3 PFC Diodes I asked you to check in post 47 are good per your report. Need to get that cap Voltage correct first, Some how you were able to get the boosted Voltage in one of your post but not now so look for bad connections on solder joints.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #77
                                    just saw this video and it looks like you have all the correct voltages seems odd if pfc is low?
                                    https://www.youtube.com/watch?v=RL5-GtwypiY
                                    so maybe watch this video and re check all your voltages as per this video as see if they match ok
                                    https://www.youtube.com/watch?v=ocqnqmBxiqY this video is good regarding pfc at about 10 minutes in but please note he is on 110v i think
                                    norcal does mention most voltage rails will run in standby but dont get full current ? untill pfc works
                                    • attainteddragon
                                      • Apr 2013
                                      • 764
                                      • australia
                                      #78
                                      just out of curiosity, have you bench tested the ps without anything hooked up?
                                      • mrobo
                                        • Nov 2006
                                        • 36
                                        • Bratislava
                                        #79
                                        Need advice : I found two diodes on the other side of board, they measured results are strange to me, look at picture
                                        DP802 = KDS184 24mV 26 Ohm both sides!!! (ok they are probably good they have low resistor connected paralel)
                                        DP807 = KDS184 2mV 1.4 Ohm both sides!!! (ok they are probably good they have low resistor connected paralel)
                                        compared to
                                        ZP801 = Z02W6.8VY 534mV PN 25.5 KOhm, which is zener, but seems for me good
                                        I have not much skill in desoldering smds, before I try could you confirm me to continue or search for problem elsewhere?
                                        I dont know how to measure the mosfet, I post mmy results for QP802 = IPA60R600CP 6.1A 650V
                                        tested like diode
                                        pin 1 - 2 = 1726 mV NP
                                        pin 1 - 3 = 1545 mV NP
                                        pin 1 - 3 = 450mV PN
                                        pin 3 - 2 = 485mV PN
                                        pin 1-3 even 3-1 = 8.4 KOhm
                                        could the mosfet bad?
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #80
                                          if your board has PFC IC (FAN 7530) i think it is i would check your getting all the correct volatges too it as for some reason the pfc is staying low
                                            09-07-2024, 05:50 AM
                                          • C152Heavy
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • sansanpartida
                                            Samsung QE82Q70RAT no backlight
                                            by sansanpartida
                                            Hi everyone!
                                            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                            My issue: No backlight.
                                            Model: QE82Q70RAT
                                            Type No: QE82Q70RAT
                                            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                            So hopefully, I can fix this cheaper.
                                            05-22-2024, 06:56 AM
                                          • howardc64
                                            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                            by howardc64
                                            TV was fixed just after removing Samsung's rear snap cover.
                                            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                            Maybe PSU->backlight connector didn't have a good contact?...
                                            07-23-2025, 12:34 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
