VW37L inverter ribbon cable removal
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Hey guys. Working on a Vizio for a co-worker that starts flickering after warm. Looks like caps on board are bad. I don't want to mess up the little ribbon cable by pulling on it and I can't see any type of release for the cable. Anyone know how to remove it?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: VW37L inverter ribbon cable removal
    pull on it. more specifically that little blue tab.
    Follow the white rabbit.
    • whiz62
      whiz62
      • Dec 2013
      • 242
      • usa
      Thanks goontron!
      • s2arto2
        Ditto, goontron!
        • DLinkOZ
          • May 2013
          • 238
          I've worked on the inverters for this same TV, and goontron is correct. Also, check that fuse - I've seen these caps go (I believe they're the 680uf?) and almost always take the fuse with them.
          • whiz62
            whiz62
            • Dec 2013
            • 242
            • usa
            Thanks guys. Replaced caps and ran it 9 hours. No more flickering.
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • zesko
              xps 9520 ribbon cable
              by zesko
              I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
              There is 2 models, idk which one is needed on my laptop.
              0xkvng
              00vpr2
              Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
              Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
              thanks...
              10-23-2025, 05:03 PM
            • lowpost99@gmail.com
              Need a replacement ribbon cable DELL Latitude E5470
              by lowpost99@gmail.com
              Anyone know if the ribbon cables are standard across laptops cases like in a PC, or are they proprietary to each manufacturer? I damaged the one that runs between the MB and the power / HDD / Battery Status Indicator LED Circuit Board. The Dell SKU/DPN: ADM70LED. I just need help finding a replacement. Could I possibly use a similar cable from a donor laptop?
              09-04-2024, 07:42 PM
            • NWArkGuy
              Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
              by NWArkGuy
              Well, I will be the first to admit that I screwed up...
              In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
              I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
              I have 2 that I have found and have in my possession. ...
              10-12-2023, 10:13 PM
            • alfredomfr1
              HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
              by alfredomfr1
              12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
              06-04-2025, 10:23 AM
