Buzzing transformer on Proscan 42LA45H power supply.
  • johnboy1313
    • Nov 2012
    • 1959
    There were a bunch of bulging caps on this one. I swapped them out with scavenged parts to test. I will order new caps from Digi-Key but there is a transformer that is buzzing loudly. At the 0:05 point of the video, the backlights come on and the buzzing gets louder. The main cap shows a little swelling along with signs of being really hot. Do you suspect changing all of the caps, including the main will stop the buzzing? Also, the main cap is a 390uf 250WV cap. I don't know what the WV stands for and Im surprised that the main cap isn't closer to 400V. Thoughts?
    http://youtu.be/vJ4Ff4gi8PY
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Buzzing transformer on Proscan 42LA45H power supply.
    WV stands for Working Voltage If you big cap is getting hot and bulging it may be dried out- Is it a single or one of a pair?
    If you have a spare big cap with higher voltage same uf, try that for a test.
    If big cap is on its way out could cause transformer noise also check for
    leaky diodes or leaky bridge rectifier.
    Noise increases when lamps come on as bigger power draw.
    • johnboy1313
      • Nov 2012
      • 1959
      Thank you. It is a single main cap. I don't have anything with the same capacitance. When ordering replacements should I stick with the 250V or go higher?
        "I don't know what the WV stands for and Im surprised that the main cap isn't closer to 400V. Thoughts?"
        This power supply does have PFC Voltage booster so the Voltage on the cap will be only around 160~170VDC range.
        Check the DC Voltage right at the two legs of the cap to see if the Voltage goes down a lot when the backlights come on. It should maintain 160VDC.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          *does not have PFC.
          Transformer buzzing is a sure sign of 50Hz ripple getting in, and indeed, that usually happens if the main filter capacitor is bad. Do not attempt to run the set anymore before replacing that capacitor, as the power supply is overloaded because of that and may blow other parts.
          A working TV? How boring!
            Sorry for typo, it does not have PFC Voltage booster and that is why the Voltage on the cap will only be in the 160~170VDC range as indicated.
            • johnboy1313
              • Nov 2012
              • 1959
              No sweat bud. I understood. Thanks for your help guys. I've been busy all day and haven't gotten back to it yet. I'll probably be ordering the caps tonight.
              • retiredcaps
                • Apr 2010
                • 9271
                One of my favourite quotes from another forum member named Toasty
                https://www.badcaps.net/forum/showpo...88&postcount=6
                "A slight bulge is like being a little pregnant."
                --- begin sig file ---
                --- end sig file ---
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I recapped the entire board. All is good. The buzzing is gone.
