Modification to a Switching Power Supply Transformer 4.0 @ 40 amp to charge 5 volt battery bank for iPad
    • Jul 2011
    • 6059
    This is the switching power supply that is used in this project
    https://www.ebay.com/itm/164440680270?var=464055952700
    Here is the BMS protection board
    https://www.ebay.com/itm/38688703079...Bk9SR47sydbRYw
    This is the first time that I have seen a switching power supply that has a 40 amp output for 3.3 volt output bypassing the USB controller charging circuit but use a single battery cell BMS protection board for charging only because when you have a very high amp hour battery pack it takes forever to charge it when at 50% percent of charge
    This switching power supply will also be recapped if needed before being put into service
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    How in the name of god do you end up with a 40amp output from a SMPS with no load on it??🤣🥹😅
      • Jul 2011
      • 6059
      I was referring to is maximum current with a corresponding load I going to use a different charging BMS to do fast charging then hook it up to the USB charger to maintain it and charge it up the rest of the way
      But the maximum BMS current rating I could find is 24 amps which would do for me I might have to split the the battery pack in two sections instead of one but even this is not a disaster because the majority of battery bank charger have a maximum of 10 amp hours anyway and then when you exceed that the battery gauge is inaccurate because it can only count up maybe 12 amp hours any way
      See I have these battery packs that are originally made for hospital computer backup and it is set up for 24 volts but I going to make my own circuit board to hold the battery cells in place but put them all in parallel so it would only have 4.2 volts
      The only thing that I have not decided on is what battery cells to use because I do not need battery cells that have more than 4 to 6 amp load capacity but have a long run time on low current applications like running an iPad for many hours away from the wall outlet
        • Jul 2011
        • 6059
        Well I had time to recap this switching power supply doing a burn in test the only capacitors that I did not replace was the 3300 @ 16 volts I only had 6.3 volt ones I have some that are 16 volt ones but they slightly too tall and the cover would not fit properly if used them I just need to order the right ones so the cover will fit properly
        I also did not replace the main filtering capacitors because I did not have this value either
          • Jul 2011
          • 6059
          I going to see if I can cut the circuit board tomorrow to fit the enclosure so I can start testing some battery cells for this battery pack because I have the battery bank boards from some battery banks that the battery cells that went so I going to put them to good use
            • Jul 2011
            • 6059
            I am rethinking the idea of using this switching power supply for this modification I found a small 12 volt @ 3 amp switching power supply and I found my 5 volt @ 60 amp switching power that is a Mean-well switching power which is a better power supply than the one that is in it and the one that I was going to use
            I just got to wire in the supply line to the small 12 volt switching power supply
            There was an issue with the switching power supply yesterday when I was testing it at 5 amps and higher that the display was getting a little bit brighter when the 5 volt rail was loaded more than the 12 volt supply rail this would be an issue over long period of time this is the reason why this was not used and a boost converter was used because of this issue which I now understand why it was done this way
            I want to put another cooling fan on the controller board that controls the display back light and the function buttons because I noticed that after running for a while the board was getting a little warm the load cooling fan only comes on when the charge/discharge functions are used but I will probably use a small 24 volt cooling fan with the 12 volt power supply rail which would make the fan run at a slower speed
            One note the temperature controlled cooling fan with the temperature sensor mounted on top of heat sink works really well with it loaded at 4.2 amp the temperature of the heat sink was very cool to the touch just what I was looking for
            The switching power supply that I was going to use for this project is going to be used in another project where the loading of the two power supply rails are not going to be an issue too deal with because they will not be in an application that requires it to be turned on and off repeatedly
            • GeirAndersen
              iPad .pcb file collection
              by GeirAndersen
              I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
              Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
              IPAD COLLECTION 1
              +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
              +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
              +---iPad mini3 820-00008(A1599) 820-00002(A1600)
              +---iPad mini4 820-00180(A1538) 820-00177(A1550)
              +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
              +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
              12-09-2024, 09:28 AM
              12 volt switching power supply modification to 14.5 volts before blocking diode add
              I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
              I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
              One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
              04-11-2021, 11:01 AM
              After all of...
              07-13-2024, 08:14 PM
              I am in need of a 21 volt switching power supply with at least 5 amp capacity
              I would be open to a 24 volt @ 5 amp switching power supply that can be adjusted down to 21 volts permanently and the over load protection is still functional and low voltage cutoff 15 volt or higher if necessary
              I would rather not have to use a buck converter to get the voltage that I need
              So is anyone else that has successfully modify one for a slight lower voltage had good results willing to share with me the safest way to accomplish this task
              I googled for a 21 volt switching power supply and did not find very much information for switching power supply...
              02-19-2023, 05:47 PM
              Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
              I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
              I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
              I used a four USB outlet and electrical plate that is made for...
              08-03-2024, 07:54 PM
