Samsung LE40C530; turned on, flickered, now no backlight (but picture/sound work).
  • nomoresonys
    • 12331
    • U.S.
    Re: Samsung LE40C530; turned on, flickered, now no backlight (but picture/sound work)
    I see, sometimes you end up with junk from ebay, but the buyer is always protected, at least for the part if not for return shipping.
    • Xandros
      • Dec 2014
      • 66
      • England
      Cynical me was wrong. They emailed me today saying they'd send a replacement and suggested I dispose of the damaged board rather than bother sending it back to them. I guess they'll be claiming compensation from UPS.
      • Xandros
        • Dec 2014
        • 66
        • England
        Got another board today. This time packaged much better! Worked too, TV is back to it's old self. So, there we have it.
        • nomoresonys
          • 12331
          • U.S.
          Glad to hear it and nice to see they stood behind their product and did the right thing.
          • saddle_au
            Waste Warrior
            • 121
            Removed due to update.
            Last edited by saddle_au; 01-15-2015, 06:57 PM. Reason: Originator updated while I was answering.
            • gladi15
              • Jul 2015
              #26
              I have a similar problem with the same model..After the tv is on for 15mins..its start flashing depending on the content of the picture.if its too much alternating between dark and white lights it start flashing backlight.
              The PSU is coded PSU - BN44-00340B no 00340A have changed the inverter the but the problem remains.can be a problem with CCFL or psu dont know which.
              One way to go around is to keep alternating between pic modes until it goes steady again but the flashing come back and gets really annoying after a while..
              Ron did you manged to get it fixed by replacing PSU or CCFL..??
              • davidpringle
                • Sep 2017
                • 5
                • uk
                #27
                Originally posted by Xandros
                Sure, here's the back of the tv, and minor close ups of both the boards. Camera isn't fantastic though so don't expect a marvel of photographic intensity though I can do a even closer close up if needs must of course. Also for what it's worth, here's the wiring diagram for the power board (the one linked in that thread doesn't work but I found it elsewhere).
                hello, iv just inherited this set and have a spare board, however the capacitors have been removed. im replacing capacitors and im looking to know what value to use. please help
                • tw2005
                  • Oct 2011
                  • 6458
                  A little vague. Photo, board number , part locations? all the CAPS?
                  • lospiratos
                    • Jun 2020
                    • 14
                    • Belgium
                    #29
                    I have the same problem with this type of TV. Has anybody ever found which component causes this kind of issue?
                      Does your TV use the same exact boards as the OP? OP got the TV fixed by replacing the power supply board to fix his issue.
                      Is your TV the same model as the OP?
                      • lospiratos
                        • Jun 2020
                        • 14
                        • Belgium
                        #31
                        Yes, exactly the same boards and symptoms. I dont want to switch the board, but fix it instead. The circuit is available so I think it should be doable.
                        • nomoresonys
                          • 12331
                          • U.S.
                          #32
                          Start with test in post #8 if you didn't already.
                          • lospiratos
                            • Jun 2020
                            • 14
                            • Belgium
                            #33
                            I already did that, then the backlight works perfectly fine. PFC voltage is 377V, is that enough?
                            To disable the protection circuit I've removed DI811. Now the backlight doesn't turn off anymore, but it flickers slightly.
                            Now I'm trying to debug the VSNS and ISNS lines, but it looks fine at first sight. It's a bit hard because I don't really know which signals to expect.
                            One thing that I've noticed is that the LD signal sometimes triggers, what's it's purpose?
                            • nomoresonys
                              • 12331
                              • U.S.
                              #34
                              That test verifies the backlights and powerboard, so if you are messing with the powerboard you are probably on the wrong trail.
                              • lospiratos
                                • Jun 2020
                                • 14
                                • Belgium
                                #35
                                The PWM signal from the main board is also correct.
                                I think something goes wrong in the PFC circuit when the inverter starts to dim.
                                  What is the PFC Voltage on the main filter caps when the backlights start flickering? <360VDC?
                                  Does it flicker less if the backlights is turned down to 25%?
                                  If you look at page 2 of schematic, there is low PFC Voltage detector circuit on the top left of the page, you can see ICP802, PCS804 and a bunch of resistor network. I expect the PFC Boosted Voltage to be around 390V typ.
                                  LD = Lamp detect, it is Lamp error signal.
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    #37
                                    Conflicting information, "the backlight works fine, backlight doesn't turn off, backlight flickers"
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      #38
                                      Disabling protection is not exactly proper procedure.
                                      • lospiratos
                                        • Jun 2020
                                        • 14
                                        • Belgium
                                        #39
                                        It allows to measure without the module shutting down after a few seconds. Those backlight states are all in different situations.
                                        Without PWM the backlight works fine at highest brightness level, this lets me think that the lamps are fine. The flickering starts when the lamps need to dim with PWM. I also don't suspect the feedback signals anymore, because the A and B output on LX6503A is constant thus not causing the flickering.
                                        How can I safely measure the PFC voltage with my scope?
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
                                        • JohnML1975
                                          Samsung UA50TU8000W no picture and no sound
                                          by JohnML1975
                                          Hello All
                                          have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                          TV will not turn on
                                          There is no standby light
                                          When I press ON button for remote the red standby light does flash but no picture and no sound
                                          From the back of the TV I can see the red light on the back of the mother board
                                          Holding torch to the screen I cannot see a picture
                                          I removed the back cover
                                          Observing the boards I cannot see any damage
                                          I disconnected the main board from the power supply
                                          the back...
                                          08-30-2025, 09:40 PM
