T-con proplem
  • rkm
    • Sep 2014
    • 17
    • ICELAND
    T-con proplem
    Hello. I have Hitachi l37v01ea at the beginning the tv was somtimes freezing but my friend try fixing the t-con but made some mistake it have lines now, but it stopt frezzing. so I bought new aftermarket board on aliexpress but when I change it have negative image. There was a extra IC chip so I change it but then I just had some lines no image. What should I do try to take the IC chip from the old board and put it on the new one ? T-CON T370HW02 V0 Control Board 06A22-1B
    p.s
    Application of the chip position in U603
    • 12128
    • U.S.
    Re: T-con proplem
    can you post some good clear pics.?, of all the boards, to get the ball rolling.
    • rkm
      • Sep 2014
      • 17
      • ICELAND
      Re: T-con proplem
      Here are some pitcure I did try to put the orginal chip on the aftermarket board and there is no lines bud the movie are split left and right you can see it at the text and also the image dont fill the screen.
      • rkm
        • Sep 2014
        • 17
        • ICELAND
        Re: T-con proplem
        and the image 4 are the orginal board.
          • 12128
          • U.S.
          Re: T-con proplem
          I think I would send the new board back, you might have gotten a bad one, if they send you another one and it does the exact same thing, you might have a problem other than the tcon.
          • rkm
            • Sep 2014
            • 17
            • ICELAND
            Re: T-con proplem
            This is proplaby the t-con because if I put the orginal then I have lines bud full screen but now with the new one. Double picture and small. Bud no lines.
              • 12128
              • U.S.
              Re: T-con proplem
              could be, you might have just got a bad one, I'd send it back for another.
              • rkm
                • Sep 2014
                • 17
                • ICELAND
                Re: T-con proplem
                So if T-con board is broken there is not possible to fix them ?
                  • 12128
                  • U.S.
                  Re: T-con proplem
                  maybe but if it's a new tcon and it don't work, why not have them send you a different one?, if you try fixing the one they sent you and you fail, then I doubt they would replace it.
                    Re: T-con proplem
                    If one board has more parts on it than the other then they are/may be not the PCB assembly. Manufacturer can use same blank board and stuff it with different parts to create more than one PCB assemblies as needed for certain screens, TV's.
                    What are the assembly numbers as printed on the bard code of YOUR board?
                    Picture #4 has P/N 5537T04005
                    http://www.shopjimmy.com/auo-55-37t0...-con-board.htm
                    • rkm
                      • Sep 2014
                      • 17
                      • ICELAND
                      Re: T-con proplem
                      I thing that it will cost me more to send it back because we have only one post service here in ICELAND and they take more than this board to send it back sender say I have to pay the sending so I was hopping to fix this proplem here on badcaps with help from you guys.
                      • rkm
                        • Sep 2014
                        • 17
                        • ICELAND
                        Re: T-con proplem
                        Ok so proplapy you have the answear here for this ! this is the number from orginal: Ut-5537T04005-753-206-1821-06778-02 aftermarket:UT-5537T04008-19-L-2005122-0006K-04
                        So Will it be possible for me to make one working out of this ?
                          • 12128
                          • U.S.
                          Re: T-con proplem
                          could try ebay, could be iffy, might find someone with free shipping, should make certain that the tcon is a match for your panel.
                          • rkm
                            • Sep 2014
                            • 17
                            • ICELAND
                            Re: T-con proplem
                            Yeah like I say hopping for fixing this proplem with a litle help. Already bougt this for 60 dollars and if I have to pay more Or another 60 dollars for this old tv. I have to be sure this will fix it. Be fore I buy new one. Or just get a litle help to fix it.
                            p.s sorry about my enghlis but I know you get the point in my answear and quistion.
                            Just of fun of it. Translate this in "google translate": ( Hvaða máli skiptir hvaða tungumál við tölum. Við höfum google! ) Anyway I dont use google to translate or write in any off of this message, whits I have writen here.. :-)
                              • 12128
                              • U.S.
                              Re: T-con proplem
                              looks like it might be a pretty detailed job, did you grab a service manual?
                                • 12128
                                • U.S.
                                Re: T-con proplem
                                pay close attention to budm he's a pro, I'm just learning, I try and help if I can but my scope is limited.
                                • rkm
                                  • Sep 2014
                                  • 17
                                  • ICELAND
                                  Re: T-con proplem
                                  No but I but I can get litle help in work if I can tell them what to do. " they are mostly working in whasher mashing and stuff like that and High voltig 12kv and 22kv Not working on tv.s hahaha.. They Services aluminum factorie. But I can do somthing by my self if I get good instructions.
                                    Re: T-con proplem
                                    http://www.shopjimmy.com/philips-996...-con-board.htm
                                    the 008 does not show as a accepted sub for 005.
                                    I have no idea as to which parts you need to add or remove to make 008 into 005.
                                    • rkm
                                      • Sep 2014
                                      • 17
                                      • ICELAND
                                      Re: T-con proplem
                                      ok so this big proplem but would it be possible to fix the orginal board. It have thin vertigle lines. Are the main chip deat ?
                                      • rkm
                                        • Sep 2014
                                        • 17
                                        • ICELAND
                                        Re: T-con proplem
                                        This is how the lines are with orginal board.
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • alltvrepairs
                                          Lg TCon test pins for screen test
                                          by alltvrepairs
                                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                          Appreciate your help....
                                          06-13-2025, 06:33 AM
