I picked this one up today, don't have the blink or LED status as I've decided to not power this up already knowing most likely shorted SC. It was described with either locked solid LED or may have been none but i was told no blink codes.
Just jumped straight into it and SC2 100% dead short, 4 screws loose on the SC, arcing and burn marks underside, burn marks under the screws and solder lands also burnt and eroded away.
very poor in comparison to my 2010 model and very poor of panasonic not to provided out of wty or recall. these are doomed from the day out of the factory.
Also these screws are not even dead flat, slight concave under the heads so only the outer rim contacts the board.
Looking like just GT30F131 and the 2 diodes although there's more than 4 30F131 showing short, hoping it's not all of these but I am going to sub these with FGD4536TM, from RS components so no risk of chinese copies, and about $1.50 each so cheap repair it should be. Also I'm going to use RF1501NS3S for b both as it's higher spec than the RFN10 and they are pretty common on panasonic sustains which I've scavanged.
I'll get some shots up showing the burns etc down the track
so essentially if it were to operate at the max it would burn up because the heatsinking is inadequate, so i really don't need to worry about the shortfall.
