Samsung UN46EH6000 LED ERROR Codes
    Re: Samsung UN46EH6000 LED ERROR Codes
    Looking at the bottom side of the board, I can see that the connector for the LEDs are setup for driving ONE LED string (only has one boost converter circuit, Q9102, D9102, L9101, C9110) so if one LED is open circuit, then you will not see any LED flash on at all.
    You can test each LED using 2 AA batteries connected in series feeding in to 100 Ohm resistor to limit the current to power up each LED.
    • Michale32086
      • Nov 2011
      • 1453
      OK, so it's like an old-style string of christmas lights... If one bulb is bad, NONE work...
      Right???
      Extrapolating from that (bear with me, this is all new ) than I can assume that ALL strips must be populated with working strips or none will work..
      In other words, I can't put just one in for testing purposes as they all have to be in and they all have to be working..
      That sum things up???
        See updated post 21 on how to rest each LED. Anode is Positive.
        • Michale32086
          • Nov 2011
          • 1453
          Whooaaa That sounds like a fun project!!
          Looks like I picked the wrong week to stop drinking..
          What the hell.. It's a nice TV and definitely worth the effort...
          So I test each individual LED (not strip) and the LED that DOESN'T light up indicates that the entire strip is the culprit..
            See this link also.
            https://www.badcaps.net/forum/showth...022#post509022
              Since they are all in series, one LED open = no light.
              If the converter is current-mode driven (not sure, but probably is), then it would be possible to short out the bad LED for a test. Still, wouldn't try this unless I was certain...
              • Michale32086
                • Nov 2011
                • 1453
                OK, got the TV disassembled again...
                Got the battery testing device rigged up. It ain't pretty, but it works... 87ohm is the closest resistor I could find here at home..
                Of course, there is a problem..
                There doesn't seem to be any way to access the connections of the individual LEDs.. The backing has a cover...
                I see two possibilities...
                Strip the backing off the LEDs and use the connections (if available)....
                Or pump up the juice and test the entire half strip (6 LEDs per) from the half-point connections ...
                I am not knowledgeable enough to know the pros and cons of either course, beyond the obvious....
                Anyone??
                • CapLeaker
                  Leaking Member
                  • 8084
                  That is preference. For me I'd test each LED string first, then concentrate on the string that doesn't work. Other's like to test each individual LED. Could be one string or LED, also it could be more than one. Sometimes you are "forced" to do a certain way, because you don't have a proper adjustable voltage with current limiting power supply to light up a whole string, or the proper voltage dropping resistor... etc. One has to make use with what you got at that time.
                  Onsemi makes an NSI45020 20ma constant current LED driver. It is very small, but the input voltage can be up to 45V DC and it will current limit perfectly to 20ma, exactly what one LED wants. I use it for incandescent to LED conversion in dials, meters etc. You could use any DC power supply that has more than 6V or so and have a perfect LED driver power supply to test individual LED's without worrying "it's gonna blow"!
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Awesome info. Thanx
                    One question though. Would the 6V+ Power Supply work if I am going to test the half-string (6 LEDs) as a whole???
                    Or would I need something beefier??
                    Thanx again..
                      6 LEDs in series = ~3.5V/LED = 21V needed to test
                      • Michale32086
                        • Nov 2011
                        • 1453
                        OK, found a wall wart that did not blow anything up... It's rated at 12v, but the meter says it was putting out 16v..
                        Referring to the attached pic..
                        I touched the 16v to the points indicated by the boxes...
                        On the Green points, all the LEDs to the RIGHT of the box lit up fine.. The LEDs to the LEFT of the box did not light up...
                        Except for the one red box on the right. No LEDs lit up at all...
                        Touching the 16v on all the boxes on the left.. No LEDs lit up...
                        Apparently, the one strip on the right side is bad.. Just to confirm, I pulled that entire strip off and tested them individually. Still no joy..
                        But I find it hard to believe that all the strips on the left are bad..
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Got it.. I'll beef up my power..
                          Thanx..
                          • Michale32086
                            • Nov 2011
                            • 1453
                            Used a Variable adapter set at 20v 4.5amp, registered at 21.2v..
                            No change from post #31
                              It's very important that your power supply be limited to a low appropriate current, so use a resistor ~220 ohm in series with the power supply output.
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Added a 220ohm resistor in series..
                                Other than a dramatic drop in the brightness of the LEDs, there was no change from the previous 2 attempts...
                                  That's good, just need to see them light up, don't want to burn them out.
                                  Is the polarity perhaps reversed for the left strips?
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    According to the labels, there is no inversion. The "upper" track is '-' and the "lower" track is '+' all the way across..
                                    But I just discovered something new...
                                    I get continuity from the left connector to the midpoint connector on the '-' only..
                                    There is no continuity on the '+' connector from the left to the midpoint. No continuity at all...
                                    • CapLeaker
                                      Leaking Member
                                      • 8084
                                      Since you don't have a current limited power supply you don't want to use a power supply that has more V output than the LED string. You just want to light them up without blowing something up, using something you already have. That 16V power supply is perfect for that. 3.3Vx 6=19.8V
                                      Using the 16V power supply you would still get 2.7V for each LED on the string and it would light up, not full brightness, but who cares... you just want to see them turning on.
                                      Either there is a short or an open on the left side of the LEDs... just where... that's gonna be the fun part to figure out. So far you are doing good, don't worry!
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        I'de feel a lot more comfortable if at least ONE of the left side strips were working... But having them ALL dark could indicate that they ALL are bad.. Or that something further up the line is the issue...
                                        Oh well... Pressing on....
                                          Those plastic LENS for the LEDs are snap in place, you should be able to remove them so you can get to the LED's to test each LED.
                                          Similar to this one:
                                          https://www.badcaps.net/forum/showpo...3&postcount=59
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • brithepi2k
                                            Samsung UE75TU7020k No picture, Standby blinks 2 times
                                            by brithepi2k
                                            My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                            04-23-2025, 10:05 AM
                                          • Caimano
                                            hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
                                            by Caimano
                                            MB G7AD-2G DAG7ADMB8D0 REV D
                                            Processor i5 8265U
                                            AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
                                            Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
                                            Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
                                            02-06-2024, 10:14 AM
                                          • Grunder
                                            Samsung UA55NU7100 2 blinks then reboots
                                            by Grunder
                                            Hi please some assistance with my Samsung UA55NU7100 that is stuck in reboot.
                                            I've read the post by Itelite on a Samsung UA65NU6900 with the same problem but this main board is different and doesn't have the 25v VGH voltage which was the problem that he had.
                                            There is no legend indicating voltages on the socket/ cable going to the main board just a link marked 11.80 volts. This voltage reads 12.71v. Pins 3 to 9 also 12.71v. Pins 2,6,8,10,11 & 12 all 0.0v. Pin 1 fluctuates 3.01 to 0.0 volts and pin 4 fluctuates 3.25 to 0.0 volts.
                                            The cpu gets very hot after 10...
                                            01-26-2024, 07:43 AM
