TV Recap - Bush (Alba) LCD2280f1080P
  • nigeH
    • Nov 2014
    • 24
    Re: TV Recap - Bush (Alba) LCD2280f1080P
    Originally posted by selldoor
    You are still thinking 2.2nF? ---- think 2.2pF
    Yes I am ... will do better next time (hopefully!!)
    Cheers,
    Nige
    • nigeH
      • Nov 2014
      • 24
      Evening all
      Any ideas where I might locate a schematic?
      Seems very similar to the JVC guide layout, but not quite the same....
      Not under Bush/Alba/Sharp/Vestel at http://www.toms-service-manuals.com/
      Cheers,
      Nige
      • selldoor
        Slow Learner
        • 7870
        I doubt you will find one- looking for anything specific? Did you try the reflow?
        Perhaps some voltage tests and powering up the PS withoit the main board might be next
        to see if the lights will say on. Can you post close up pictures of area around the red socket on the PS front and back and the same on the main board at the other end of the connector. Alos can yo do a better picture of the back of the power supply and straight on pictures of the fronst and back of the main board. (daylight is best if you get any )
        • nigeH
          • Nov 2014
          • 24
          Hi... thanks for your help... I've tried a few things and done some reading
          - removed and resoldered the HV Caps (and ordered the eBay ones in case!)
          - changed the 1000uF for some I had in the drawer to see. Fitted caps tested as (in ohms) HEC 1.8M, 1.4M 1.2M and the SAMXON 5.4M
          - reflowed an ugly blob joint on a SMD cap in the HV DC section just in case.
          No difference.
          With Mainboard connected the point arrowed (in the Top view) changes from the steady 3.84V and rises over two secs to 2V when it trips out.
          It runs on standby with the mainboard disconnected (there are only the two boards (plus a tiny one for the RC off the mainboard).
          Put a load on the 5V rail (20W Halogen bulb) it glows as you might expect. Same bulb on the 12V rail and it trips out immediately.
          Tried before and after the IC804 12V regulator with same result.
          Pictures as requested attached - with the standby voltages on the topshot. Can re-crop or re-take if needed - have daylight if not sunshine
          Any thoughts on my next move?
          Cheers,
          Nige
          • selldoor
            Slow Learner
            • 7870
            OK just typed a lengthy note and got logged off before I could post it
            here is the condensed version
            Pic five top right small fuse with an "s" on and Pic2 top right 2 "0" rated
            resistors - please test as fuses.
            Red socket -test with all connected v at each pin.
            Disconnect main and test again.
            Ideally it is nice if it can also be tested in the short period when the light is
            on - a few pins at a time, but that may not be essential.
            Did you get to looking at making up test bulb/s from a 11-14w cfl
              Vestel schematics under OEM (since they are one)
              http://www.toms-service-manuals.com/...&Search=Submit
              Top result.
              • selldoor
                Slow Learner
                • 7870
                #27
                Doh! thanks Tom I too looked under Bush and Vestel couldnt believe none came up as I know how much you like them .
                Perhaps on Vestel Tips a note "See OEM for schematics" for us memory sieves
                • nigeH
                  • Nov 2014
                  • 24
                  Top result.
                  Thanks Tom... now you've pointed them out I can't see why I didn't find them...!
                  I hate it when that happens! Thanks for re-typing
                  Progress (if you call it that) thus far I have tapped out the voltages on the connector. 3.3V amd 12V coming back look a bit odd. See attached. Checked the fuses you pointed out and all the other Fxxx I can find - all ok.
                  So having watched the excellent video on testing regulators I checked the three on the mainboard.
                  U12 :output 1.872V from 3.25V supply and 0.608 reference
                  U122 output 5.15V from 7.97 supply and 3.88 reference
                  U123 output 7.98V from 13.11 supply and 6.71 reference
                  Seems in order
                  Then I realised the PSU and Mainboard are stable as no panel and tubes connected - added the panel and still stable.
                  Tried the CCFL one set at a time - the set on PL101/102 cause a flash like a lightbulb (same as when both are connected) and the set on PL103/104 caused a longer (half second) flash.
                  Wired up a test bulb as per another video on this rather fine site and this illuminates for half second duration on both.
                  I've removed TR100.
                  The windings look clean - 860 ohms on each secondary - should the primary be 0.1 ohms?
                  Cheers,
                  Nige
                    https://www.badcaps.net/forum/attach...0&d=1416149675
                    What are the P/N of those two POWER MOSFET IC102, 104?
                    Check the resistance between any one of the pins on the right side against the other 4 pins on the left side of the IC and report the readings.
                    Also check the resistance of the FUSE F101, <1 Ohm?
                    • nigeH
                      • Nov 2014
                      • 24
                      Hi budm - checked these out:
                      Fuse F101 reads 0 Ohms
                      Part number for both is PK8J FDS 8962C
                      Also noticed none of the other components on that section of the diagram are fitted - D134 and D136 & C139, 140, C115 and C142.
                      Resistances
                      IC102
                      Pin 1 10M
                      Pin 2 10M
                      Pin 3 2.1M
                      Pin 4 2.2M
                      IC104
                      Pin1 10M
                      Pin2 10M
                      Pin3 2.4M
                      Pin4 2.2M
                      These do vary - pin 1/2 falliing and 3/4 rising. Other parts of the circuit I guess.
                      Checked the voltages - getting 13V on the outputs until the reset. 6V during standby. All without the tubes attached.
                      Cheers,
                      Nige
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        http://www.alldatasheet.com/datashee.../FDS8962C.html
                        Was that with one test bulb AND the normal bulb in place on the other socket?
                        Just remind me is this 2 bulbs or 4 - if 4 then you need 3 and the test bulb
                        • nigeH
                          • Nov 2014
                          • 24
                          YYYYYYEEEEEEEEEESSSSSSSSSSS!!!!!!!!!!!!
                          Four bulbs - thanks for that, I had them all unplugged.... plugged in 3 and used the probe bulb and worked along until they stayed on....
                          Massive thanks to you all for your help and encoragement
                          Now all I need is a source of tubes and some luck taking the panel apart... Any tips or UK sources for tubes? Panel is 290mm and nine tubes - however tha splits into 4 only time (or a drawing) will tell
                          edit - it's edge lit 4 x 480mm
                          Cheers,
                          Nige
                            I said it would be a bad bulb! But I -had- thought the LG ones were mostly immune...
                            • nigeH
                              • Nov 2014
                              • 24
                              Yes you did.
                              Sorry it took so long to catch up!! On the upside I learned a few things along the way....
                              Tubes are CCFL so perhaps an early (or cheaper) screen?
                              Once it works again I might try and find out why it whines on standby
                              Cheers,
                              Nige
                              • selldoor
                                Slow Learner
                                • 7870
                                #35
                                Hurrah!!!!
                                I dont know about bulbs in the uk perhaps someone else will chime in.
                                Going out so didnt have time for a good look - this caught my eye and if you could wait
                                a bargain (if they work and get here in one piece - at that price good for a laugh
                                http://www.ebay.co.uk/itm/New-2PCS-2...item3ce69b9a44
                                You will need the right diameter though
                                • nigeH
                                  • Nov 2014
                                  • 24
                                  Hurrah!!!!
                                  Thanks (again) for your help selldoor
                                  Got the verniers out - they are 2.4mm.
                                  Might have to get some of those just in case nothing more local turns up.... and recalling the order of assembly might be fun after a month!
                                  Cheers,
                                  Nige
                                  • chth96
                                    Is it no harm to replace with capacitor without ripple current rating?
                                    by chth96
                                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                    Rubycon YK DataSheet (b...
                                    04-19-2024, 05:19 AM
                                  • Antonynl
                                    What are typical ripple voltages on a laptop motherboard?
                                    by Antonynl
                                    I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                                    So I have two questions:
                                    1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                                    2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                                    Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                                    12-09-2022, 06:51 AM
                                  • FlailingEngineer
                                    Help with Bush Tv (Vestel 17mb95m Mainboard)
                                    by FlailingEngineer
                                    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                    05-31-2023, 06:52 AM
                                    ASUS P5GC-MX motherboard recap
                                    by momaka
                                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                    So here is what the motherboard looked like with its original caps:
                                    CPU VRM area up close…...
                                    01-27-2021, 11:59 PM
                                  • Y. Signal
                                    Recapping Mean Well MWP-606
                                    by Y. Signal
                                    Hello, I have this arcade power supply that I'd like to recap for maximum reliability and lifetime since I have found some Capxon and Jamicon capacitors:
                                    • Capxon GL 10x25 1000uf 16V Ripple: 1180 Impedance: 0.05ohm // Chemi-con KY 1000uf 16V Ripple: 1400 Impedance: 0.046ohm
                                    • Capxon GL 10x12.5 470uf 16V Ripple: 722 Impedance: 0.095ohm
                                    • Capxon GS 10x15 22uf 50V 85ÂșC Ripple: 100
                                    • Capxon KM 47uf 50V Ripple: 125
                                    • Jamicon TK 1uf 50V Ripple: 12
                                    • Jamicon TK 4.7uf 50V Ripple: 36
                                    I have another PSU (same model) that uses Chemi-con KY instead of Capxon GL, and since Panasonic FC are very...
                                    03-03-2019, 07:44 AM
