Technika 32-270 Vertical 4" Line
+ More Options
Posts
  • NipZ
    • Jul 2013
    • 106
    I purchased this Technika 32-270 from a lady as faulty. She explained that when she split with her ex he tore the power cable from the back of the tv. I replaced the power cable that plugs in internally(not a kettle lead) and the tv worked but I noticed this fault with an approx 4" vertical line running from top to bottom just off center.
    Can anyone confirm my worst fears that it is a tab problem on the panel itself, or could it be a T-Con problem?
  • selldoor
    Slow Learner
    • 7870
    Re: Technika 32-270 Vertical 4" Line
    Looks like a tab bond problem to me, but you could always try reseating the lvds cable
    • NipZ
      • Jul 2013
      • 106
      Thanks for the reply selldoor. I've already tried reseating the lvds cable with no difference.
      Does a tab problem make this unrepairable? No chance it's T-con?
        Bad LCD panel in my opinion. Can try tabs - rarely successful on individual area faults though.
        • NipZ
          • Jul 2013
          • 106
          Ok, thanks for the input. probably list this on Ebay for spares then.
          Thanks again
            Since it's a Vestel, the PSU and main board are probably worth about £15-20 each.
            • NipZ
              • Jul 2013
              • 106
              Ok, thats worth knowing. Not to bad as it only cost me £25 for the tv.
              • otaku_nut
                Vizio E701i-A3 fixed but now has red vertical line
                by otaku_nut
                Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                08-19-2025, 06:11 PM
              • TrueSword88
                Kogan - KALED65XU9220STB - Blue Vertical Line
                by TrueSword88
                Hi all.
                I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                The line just happens to coincide with the end of COF and start of the next COF (attached).
                The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                Hoping to fix...
                05-05-2023, 04:28 PM
              • almarhum
                To fix laptop screen vertical line by working on its EDP cable
                by almarhum
                Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                05-07-2024, 02:12 PM
              • mrsith
                Samsung UE58TU7100K - no picture, vertical line
                by mrsith
                Hi.
                Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                02-07-2023, 11:18 AM
              • bdalkiran
                55EC930V white vertical line appeared (need help)
                by bdalkiran
                Dear All,
                I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
                Please advice how to proceed and what is the...
                01-13-2023, 04:16 PM
