Tx-p42x60b
  • thuss
    • Jul 2012
    • 317
    • uk
    Tx-p42x60b
    Hi
    I've got a Panasonic plasma tv model number TX-P42X60B. No picture just led light flashes/blinks 3 times repeatedly.
    3 red flashes I have been told is due to a faulty D board.
    Has anyone come across this before, What is a D Board -I think the D board refers to the main board?
    Any help would be appreciated.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Tx-p42x60b
    You may be able to narrow it down to the 3.3v section if the following is correct.
    Blink Codes and what they mean :
    1 blink STV 5v sense DG Board
    2 blinks 15v SOS D Board
    3 blinks 3.3v SOS D Board
    4 blinks Power SOS P Board
    5 blinks 5v SOS D Board
    6 blinks Driver SOS 1 SU / SD / SC Boards(SC energy recovery circuit)
    7 blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
    8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
    9 blinks Panel Config. SOS
    10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
    11 blinks Fan SOS PB Board
    12 blinks Sound SOS H Board
    13 blinks Communication error DG Boardwith IC8001
      Re: Tx-p42x60b
      This is a very new set - 2013 vintage - no separate D board, it would be an A board fault. I believe the A board is identical to the TX-P42X50B series which may help in getting a replacement.
      • thuss
        • Jul 2012
        • 317
        • uk
        Re: Tx-p42x60b
        Thanks tom66 and selldoor. But I am I right to assume the A board is the main Board (theres plenty of them on ebay)
        I just cant find anything that will indicate the letter what letter goes with which board
        • Neelix
          • Oct 2013
          • 145
          • South Africa
          Re: Tx-p42x60b
          A board and main board are same thing yes
          • thuss
            • Jul 2012
            • 317
            • uk
            Re: Tx-p42x60b
            thanks
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • huj3r
              Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
              by huj3r
              Hi there!
              I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
              Photo of the situation after the black shadow dissipates:
              After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
              I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
              > This indicates HFR Communication error. [ HFR Communication...
              08-15-2023, 10:55 AM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
