Sylvania LC320SS8 A turns on for a split second then black
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    I got a sylvania model in title that has the standby light and when i press the power button the green light flashes like it should then the screen flashes with its "digital television" logo and then returns to its standby light state. i can press the power button to repeat the process.
    I have not taken it apart yet to check for bad caps or other 'tronics.
    will update when i get apart.
    but any ideas, or maybe theres a common fix?
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    Re: Sylvania LC320SS8 A turns on for a split second then black
    finally have it set up and opened.
    as you can see by the 2 images i've uploaded there are no bulged caps. i tested for shorted diodes (not the zener type) and output transformers all seem close to the same.
    i have a few cfl test lights and a spare ccfl from a 17" monitor. i did try various combinations, but it made no difference. i also have a dmm, scope, and esr meter.
    Better pictures can and will happen, when there is sunlight, which doesnt exist in the late pm.
    Not sure what to check from here.
    • capkid
      • Oct 2010
      • 1339
      I remember reading about this issue a few years ago when I purchased John Preher's repair guide: http://preher-tv.blogspot.com/2010/0...-repaired.html
      LG Plasma Mal-Discharge Correction Service
      • jasonbay13
        • Jul 2014
        • 185
        • usa
        i just checked all the secondaries as shown in that link. all were between 505 and 513 ohms.
          • 30911
          resolder the 4 big diodes.
          it's probably not related to the problem, but obviously they get pretty hot.
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            I just picked up a slightly smaller version LC260SS8, looks to have the same power board as yours. Mine has standby and the inverter board appears to be working. 172vdc on wires from inverter to power board. Voltage on output diodes climbs for a second when power button is pressed then drops back off. There doesnt appear to be any shorts beyond the secondary but I didnt get a chance to pull the power board and check the backside. Will try to check esr and look for shorted diodes on back of board tonight.
            Yours sounds like the power board is working and the trouble lies on the inverter, do you still have sound after the backlight kicks off?
            Liberating magic smoke one part at a time
            • jasonbay13
              • Jul 2014
              • 185
              • usa
              the tv goes back into standby so there would be no input.
              i'll resolder those diodes. though i think it is triggering the protect circuit, but why is the question...
              • Comm
                • Nov 2014
                • 8
                Common problem, the leads to the CCFL's are breaking down and arcing to each other. You can insulate them with liquid tape or silicone. If you move the red wire away from the white wire you can see the breakdown, or even turn off your lights and look for the arc, but be careful of your hands
                • Comm
                  • Nov 2014
                  • 8
                  I guess I should clarify, pink wires, lol and whites. Also, I mean RTV or silicone sealant not silicone lube. You can also loop the wires and wire tie the excess length of wire to get them away from each other. Electrical tape will work also.
                  • jasonbay13
                    • Jul 2014
                    • 185
                    • usa
                    thats the first thing i thought when googling. guess i forgot to mention it here. i had moved the wires so they wouldnt touch and still same result. i had 4 test lamps connect at once too, no difference.
                    and still havent gotten around to that resolderig yet... where do the days go
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Hard to tell from your pictures but a few of the wires from the inverter to the bulbs look to have arcing marks on them. Check out this post.
                      https://www.badcaps.net/forum/showthread.php?t=26417
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Guess I should have read the entire thread. Sorry.
                        • jasonbay13
                          • Jul 2014
                          • 185
                          • usa
                          so, with further dis-motivation i set the tv aside for a good long while. i came back to it, on the bottom connecting to the corner pin #13 of a chip that the best i could try reading was ma9683 i found an exploded smd ceramic capacitor. i tried putting on another from a random board i had laying around (i have no idea how to tell value) but picked one of same size. the screen lasts almost two seconds now instead of less than half a second, but is still going black. all the output tansformers are good with ohms, electrolytics are good, regular diodes are good. no direct shorts on transistors.
                          bottom leftmost chip is one i am referring to, sorry for crap quality. i can get actual pic of board if you think theres a chance of getting it working. otherwise just tell me to forget it and i'll keep the boards for parts and toss the lcd.
                          • jasonbay13
                            • Jul 2014
                            • 185
                            • usa
                            : i decided also to try the test lights again, 1-4 first which ended up with no difference. 3-6 it stayed on while the lights flashed like a strobe light, going to 4-6 the same happened, but strobed quicker. i tried going further by doing 5 & 6, but it shut off after a second, looks like if i have any of the ccfls plugged into 4,5,or 6 it shuts off. but with test light it stays on and strobes.
                            • Stephen
                              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                              by Stephen
                              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                              03-15-2024, 09:37 AM
                            • www
                              LG L192WS-BN backlight turns off after 1 second
                              by www
                              I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                              I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                              03-24-2024, 05:26 PM
                            • andrhouseolly
                              Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                              by andrhouseolly
                              Hi.
                              I kindly ask you to help me solve the problem.
                              Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                              The board turns on, there is no image.
                              Read more. When the power supply is connected, the front panel indicators light up briefly.
                              When you press the power button, the button indicator lights up. The board works
                              there is no image, there is no matrix initialization, there is no image on HDMI.
                              When turned on, the fans do not spin, but when they warm up they start spinning.
                              When you turn off the button, the fans spin up to full speed for a short...
                              05-11-2024, 03:14 PM
                            • predator0357
                              Haier LE50M600 turns on but only for a split sec
                              by predator0357
                              Hi
                              got this TV to repair, it turns on but only for a split sec (flash).
                              Any suggestions? what to check first and so on?...
                              03-06-2021, 08:20 AM
                            • Egidio85
                              Samsung UE55F8000SZ Turns on and off immediately
                              by Egidio85
                              good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                              This defect happens continuously, hearing the classic click of the relay every time.
                              Power supply board BN44-00636B
                              disconnecting the mains and lamps from the power board always causes the same problem.
                              Is it normal that without anything connected this power supply turns on and off cyclically?
                              any suggestions on what to check?
                              thanks in advance
                              03-11-2025, 12:45 PM
